Hi guys Has anyone got windows 7 64 bit pro for me to put on a usb stick, i have the disk and serial key but ive bought an nzxt h440 case and that doesn't take a cd drive Thanks guys
You'll definitely need XHCI for that, and a USB 2.0 port. Win 7 via USB 3 is a nightmare. I've got a legit ISO on my Google drive, so here you go. https://drive.google.com/file/d/0BzGbPWf1VNMCNXkwaVRFcWFMdlE/view?usp=drivesdk
No problem. That's for ultimate, but when you've put it on a memory stick, go into the sources folder and locate a file called ei.cfg and then change the edition from Ultimate to Professional (open with Notepad). Alternatively, leave the line blank and it will give you every installer from Win 7 Starter to Ultimate.
http://the-eye.eu has an MSDN Mirror publicly available. You need a key for anything that needs a key obviously.
