Hey, i seem to have this issue every time i turn my computer on. The problem is my mouse cursor always goes off screen on the right hand side. To stop it from happening i have to right click the background then Screen Resolution then Detect the screen before doing so it shows me having duel monitors which i haven't got so i guess that's why the mouse cursor is going off. Its annoying having to do it every time i turn my computer on so is there a fix for it? Videos can be provided. Thanks
Buggy drivers I see. I suggest to uninstall the drivers, restart your computer, and download and install the latest drivers. This essentially SHOULD reset all drivers settings and of provide you with the latest drivers. If that doesn't help, than turn off the computer, and switch DVI port (if you have a second),turn it back on, and see if it helps.
