Windows Windows 7 Public Beta News
Discussion in 'Software' started by icutebluezone, 8 Jan 2009.
  1. RR5
    RR5 What's a Dremel?
    7 Dec 2003
    I've got a 2.5 GB iso for the 32-bit Windows 7 but cannot locate the 64-bit DVD for some reason. I could start everything friday night and let it run all saturday but my last experience with torrenting is people leech and never seed, so when I drop out nobody can get the file.
  2. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    That's exactly what you get at TPB: iNKiSO's releases are the ISOs, as downloaded from Microsoft, completely untouched.
  3. Blademrk
    Blademrk Why so serious?
    21 Nov 2003
    Win 7 died on me this morning. I've just finished re-installing (and that turned out to be a chore as it kept telling me I couldn't install on this drive no matter what I tried. I ended up stripping the PC down and starting again from scratch.)
  4. null_x86
    null_x86 Thread Closer
    18 Jan 2009
    odd, bad drive perhaps? Normally the only thing that does that to me is when I have a HFS+ Partition installed before Windows (or before the time of the re-installation)
    @RR5/perplekks45
    If your using a low or high seeded/leeched torrent, expect it. If you get a medium seed or high seed with low leech, then you should have good speeds. Its only when the Leech matches the seed (or is higher) that you have crappy speeds...
  5. Blademrk
    21 Nov 2003
    I've had the same problem with 3 seperate drives now (2 PATA and 1 SATA). I could boot in safe mode (which said the Intel Bus driver was the problem). However booting into the OS proper alternated between being fine, and windows hanging, start button only showing the outline when clicked and Ctrl-Alt-Del not doing anything.
    I've pretty much replaced all the hardware in my system from the 1st Win7 install, and I still get the same problem (the only common hardware left between the 2 systems are 2 HDD's I use for music and documents).
    Edit: Just froze again when the Action centre tells me that my AV/firewall (Kaspersky) is not running.
  6. ozstrike
    ozstrike yip yip yip yip
    19 Sep 2004
    Is there a way to view all folders that are shared on the computer? I'm sure there was a way to do it somewhere, where you could see all the folders that were currently being shared and manage them. Can't seem to find it now.
    Sharing is a bit of a mess right now tbh.
  7. hodgy100
    hodgy100 What's a Dremel?
    2 Jun 2008
    OK i finnaly got round to buying some blank dvd's and ive burnt the windows 7 RC1 to a disk. just asking if its worth the haste to set up? if i just do a upgrade installation over vista will all my aps be saved?
  8. M4RTIN
    M4RTIN What's a Dremel?
    11 Sep 2006
    i had that problem, with kaspersky crashing all the time and it taking the whole computer down with it, only recently tho so maybe it's an update thats done it. couldnt be bothered to continue with 7 after that
  9. Blademrk
    21 Nov 2003
    I just uninstalled it, DL'd Panda AV and it works fine (would have installed AVG but the installer kept saying it wasn't compatible with this version of windows despite having a compatible with Win 7 on the download page :wallbash:).
  10. Turbotab
    Turbotab I don't touch type, I tard type
    4 Feb 2009
    Avira works fine with W7 RC
  11. null_x86
    18 Jan 2009
    Avira works with all builds up starting with 7000 or 7022 and up, I can confirm this as when i had win7 installed, it was working nicely...
  12. Paradigm Shifter
    10 May 2006
    I tried Kaspersky with Windows 7, but ditched it when I needed to set an exception for Steam.exe so Kaspersky wouldn't think it was a trojan. I don't like having to set exceptions, as it means that if there is ever an infection in said excepted place, it'll get ignored.:worried:
  13. kenco_uk
    28 Nov 2003
    Works fine on 7057 x64 here :) Can't ged rid of the popup ad each time it updates, despite creating the avnotify.exe folder :/
  14. null_x86
    18 Jan 2009
    same here... right now im just using a cracked copy of Norton 360, so none of that whole notification stuff lol, but it does get irritating
  15. mm vr
    mm vr The cheesecake is a lie
    18 Nov 2007
    Ummh yea sorry for giving bad advice about making the avnotify.exe folder... :blush: Tried it myself and didn't work. :(
    Use this method instead: http://www.wikihow.com/Remove-the-Popup-Ads-in-Avira-Antivir
    That one is tried by myself (and using it currently) and it works for sure. :)
  16. ozstrike
    19 Sep 2004
    Gah, Lightroom has stopped working. No errors or anything, it just doesn't do anything when I click on the shortcut. :(
    Edit: reinstall fixed it.
  17. Smilodon
    Smilodon The Antagonist
    25 Mar 2003
    I finally got RC1 up and running. :D
    No major problems so far. The only thing I had to tweak was to set the installer for my sound card drivers to compatibility mode (It's nice to see that they have XP SP3 and Vista SP1+2 included this time as well).
    And my display Link adapter won't work in portrait mode with aero enabled. (It will only show the cursor (Lots of cursors, actually) and nothing more). In landscape it works just fine. :confused:
    And GTA IV works without any problems! :) (No need to mess about with compatibility mode). It have some weird bug that make it run on only one core during loading, making the GFWL login very slow, but as soon as the game loads it runs fine.
    I also installed it on a laptop. Works without any problems. It seems to run a bit hotter than Beta1, though. Need to look into that a bit further later.
    All inn all, looks very good so far. :thumb:
  18. Prometheus
    Prometheus Minimodder
    26 Jun 2004
    I've just installed RC1 on my pc and must say I like it, not that I had any issues with vista on my brothers pc alhough it was always a little slow.
    I'm more used to XP so I took my time learning where things were but so far so good. I had a small problem with spybot in that after I installed it i couldn't start Win 7 it just kept stalling on the welcome screen.
    I've also noticed it runs hotter too, geneally at idle in xp its sits between 35-40 depending on room temp and never really went above 60-65 under load. with win 7 it seems to idle at 45-50 and gets right up to high 70s under load. I'll have to keep an eye on it and maybe reinstall the water cooling sooner than I was planning to.
  19. perplekks45
    9 May 2004
    I highly doubt that your risen temperature has anything to do with Windows... unless you have your GPU in that loop too. But... nope, shouldn't happen. And if at all then less then +10 degrees. :eyebrow:
  20. Smilodon
    25 Mar 2003
    In my case it's in the same "loop" (A copper piece on the GPU connected to the CPUs heatpipe).
    It's not much, but it's enough to make the fan run constantly.
