Windows Windows 7 Ultimate 64-bit - no sound
Discussion in 'Software' started by itsonlydanny, 20 Mar 2011.
  1. itsonlydanny
    itsonlydanny What's a Dremel?
    23 Feb 2010
    Hi,
    I took the plunge this afternoon and installed Windows 7 Ultimate 64-bit - to dual boot alongside my 32-bit Windows XP Home. Everything went fine, except for one thing - no sound!
    I've got a Creative Sound Blaster X-Fi Xtreme Gamer sound card. However, I couldn't install the drivers, either from my original install disc or from the website - they do not seem to be incompatible with a 64-bit edition of Windows 7 (or so it seems). Nor could I install the Realtek High Definition drivers, I just get the message - "No driver was supported in this driver package". I've tried downloading & installing loads of different version of RealTek from numerous sites, but always with the same result.
    Any idea as to what can be done?
    Thanks,
    DANNY
  2. Deders
    Deders Modder
    14 Nov 2010
    I'm running 7 with sound with an Xtremegamer using the 2.18.0015 drivers from here
    Edit: but use the second ones down, the first ones are for Vista.
  3. moody89
    moody89 Minimodder
    19 Feb 2011
  4. itsonlydanny
    23 Feb 2010
    Ok,
    Even though I'm pretty sure these were the drivers I was trying to install, I will give them a go - wish me luck!
    Thanks,
    DANNY
  5. moody89
    moody89 Minimodder
    19 Feb 2011
    You may have to right click the .exe files and choose run as Administrator. I've had this issue when trying to install several programs in Win7 and its given me errors. Let us know how you get on!
  6. GoodBytes
    20 Jan 2007
