News Windows 8.1 Update 1 installation problems continue
Discussion in 'Article Discussion' started by Gareth Halfacree, 14 Apr 2014.
  1. Gareth Halfacree
    4 Dec 2007
  2. Corky42
    Corky42 Where's walle?
    30 Oct 2012
    I'm confused, wasn't Windows 95 the first time we saw the start menu.
    I thought NT 4.0 came out a year later.
  3. Gareth Halfacree
    4 Dec 2007
    You're right; I had it in my head it was t'other way around. Fixed, ta!
  4. willowthewhite
    willowthewhite Minimodder
    7 Nov 2006
    Shouldn't that be Windows 8?
  5. Gareth Halfacree
    4 Dec 2007
    Lawks a reekie, I'm not having a good start to the week, am I? Typo fixed, ta!
  6. loftie
    loftie Multimodder
    14 Feb 2009
    Another 40 page thread on the MS forums here.
    Mine was fixed by doing a system restore back to March, though some people still have the issue even after a refresh/reinstall.
  7. [USRF]Obiwan
    [USRF]Obiwan What's a Dremel?
    9 Apr 2003
    And still since my pc upgrade from 8 to 8.1 I got random mouse pointer freezes and it will not go in to suspend/sleep mode every night and when it does work it's doing it when I need it to be awake. For the last one I tried all kinds of crazy suggested fixes mentioned in forums on the interweb.
  8. Malketh
    Malketh What's a Dremel?
    22 Jan 2008
    Adding a couple of pointless cents to the the pile I was only able to successfully update my Surface Pro after refreshing it back to 8 RTM (apparently when you update to 8.1 it won't update your recovery partition like it will on the RT), and the repatching from there, which is painful on a wifi shot in the middle of nowhere.
