News Windows Blue ISO leaks ahead of launch
Discussion in 'Article Discussion' started by Gareth Halfacree, 25 Mar 2013.
  1. Gareth Halfacree
    4 Dec 2007
  2. Tangster
    23 May 2009
    Yay! Now I can use the reader app from metro instead of adobe acrobat. (Genuinely pleased, acrobat sucks).
  3. kenco_uk
    28 Nov 2003
    Sounds promising.
  4. Marvin-HHGTTG
    Marvin-HHGTTG CTRL + SHIFT + ESC
    10 Oct 2010
    Could try one of the alternative PDF readers - I use Sumatra PDF personally.
  5. fdbh96
    fdbh96 What's a Dremel?
    29 May 2011
    "The biggest change to the tile-based user interface previously known as Metro, however, comes in the form of rudimentary multi-tasking: rather than taking over the entire display, apps running in the Modern UI are now able to run side-by-side with each taking up half of the screen space. That might seem like a pretty basic feature to be headlining in an operating system due for release in 2013, but it marks a clear admission from Microsoft that perhaps the Modern UI is a little too streamlined for everyone's taste."
    Im pretty sure youve always been able to do that. The new feature is that they can run in 50/50 mode not just in thirds.
  6. Gareth Halfacree
    4 Dec 2007
    Oh, issat so? I'll go and correct that, ta: I was of the impression you couldn't. (I've played with Windows 8 in a VM, but haven't spent much time in the Modern interface.)
  7. Xir
    Xir Modder
    26 Apr 2006
    A major issue that, I believe it was a "Fight Club" quote "can I have the Icon in Blue?" Ah, yes, the stress of beeing a manager
  8. Corky42
    Corky42 Where's walle?
    30 Oct 2012
    It all seems pretty basic TBH, was it just me that was expecting more from blu ?
  9. Nexxo
    Nexxo Rotate Your Owl For Science
    23 Oct 2001
    To me it feels a lot more polished, and starting to bear some hallmarks of their "Vision of the Future" interfaces that they have been playing with.
  10. Tangster
    23 May 2009
    You can't say something like that and not tell us how!
  11. Nexxo
    23 Oct 2001
    Simples. Upper right corner, grab a task, drag it to the left or right border of the screen and the divider appears. Drop to the side of the divider.
    EDIT: actually there are a few interesting tricks in Windows 8/RT that aren't mentioned but I've stumbled over:
    - If you pinch-zoom in desktop Explorer windows, the icons resize.
    - When you drag the Metro volume up and down, you don't have to keep your finger on the bar, you can move away from it. Metro then draws a line from your finger tip to the slider it controls at that moment.
    - Under the Devices charm, under the printer icon name it will tell you if ink is low or printer needs attention.
  12. fdbh96
    29 May 2011
    What Nexxo said...
    However as I mentioned, it limited to a 1 third/2 third split at the moment which is annoying as 50/50 would be far better and more useful.
    I still probably won't use metro apps, and 50/50 snap has been on the desktop for ages.
  13. XXAOSICXX
    XXAOSICXX Minimodder
    20 Apr 2011
    Cornflower blue, to be precise :)
  14. Xir
    Xir Modder
    26 Apr 2006
    Ahhh! I saw it in German, and couldn't find the exact quote yesterday Thx!
  15. Corky42
    30 Oct 2012
    I don't mean to bash 8, but i just cant hold back anymore :duh:
    I just find it amazing that people are getting excited about features that have been available for a very long time before the full screen start menu.
    Accent colours available in the personalisation options has been boosted, versus 16.5 million in older OS's.
    Changing the size of the start screen icons, we have been able to do that for ages until 8 restricted it.
    Being able to run applications with a 50/50 split, hell in previous OS's we could arrange applications in any damn way we liked :wallbash:
  16. impar
    impar Minimodder
    24 Nov 2006
    Greetings!
    Ever imagined the amount of positive reactions to full resizable metro apps when that appears? :hehe:
  17. fdbh96
    29 May 2011
    Note that Im not saying that win8 is perfect its just that microsoft would probably justify with the following suggestions:
    1. Youve never been able to do this (easily/well) with a tablet on windows before.
    2. The start screen is not the desktop (ie the icons) its meant to replace the rather cumbersome start menu with all the clicks and so on.
  18. rayson
    rayson Damn sure it was legal
    23 Jul 2010
    there is still an insane amount of dead space which i think is being wasted. on the start menu
  19. Nexxo
    23 Oct 2001
    Well, that's not entirely true, is it? The original Start Menu icons could be toggled between small and large; that's it. And you can still arrange desktop applications any way you want.
    Yeah. Although it will be exactly what you want, you'll complain that it is too late. :hehe:
  20. impar
    impar Minimodder
    24 Nov 2006
    Greetings!
    Apps running inside resizable windows... what an improvement!
