Windows Windows & installation problems
Discussion in 'Software' started by slaw, 11 May 2009.
  1. slaw
    slaw At Argos buying "gold"
    13 Feb 2003
    hi guys
    i decided to try out windows 7 on the weekend but i have come across a problem with the installation. i installed Windows to a freshly formatted HD. it seemed to install correctly but when the machine rebooted the final time, i had a black screen with windows 7 written in the bottom corner
    i rebooted and tried to go in to safe mode but i had a error saying that windows could not be stared for the first time in safe mode.
    bummer
    i think my PC may not be up to specifications. i have the following:
    2 gb ram
    GA-965P-DS3
    Intel Pentium 805
    ATI x500
    can you guys please help
    thanks
  2. oasked
    oasked Stuck in (better) mud
    24 Aug 2005
    You should be fine, got the latest BIOS installed?
  3. slaw
    13 Feb 2003
    hi
    i havent. i didnt even think of that! i will give that a go.
    i am worried that my graphics card is not up to the job. do you guys think that my old ati x500 is up to the job?
    thanks
    ed
  4. NikoBellic
    NikoBellic Tech Addict
    9 May 2009
    I think that your GPU should'nt be the problem... (W7 can always just disable the aero features, which would basically make it the same as XP)
    I would imagine that you RAM could be playing a part in this isuue,
    try leaving just one stick of RAM in, then see if it works, if not, then try swapping that with another stick to see if you RAM could be the problem...
    Good Luck! :thumb:
  5. Jux_Zeil
    Jux_Zeil What's a Dremel?
    30 Apr 2009
    I'm sorry to say that I think it's the GFX card. Windows 7 seems to be a bit fussy about which cards to run. Until the driver releases improve you might have to wait.
  6. slaw
    13 Feb 2003
    thanks for you prompt help guys.
    i will try it with the latest bios and with 1 stick of ram but i suspect that i will need a new graphics card :(
    can you guys suggest a cheep (ie less than £50) graphics card that will up to the job?
    thanks once again
  7. oasked
    24 Aug 2005
  8. NikoBellic
    9 May 2009
  9. slaw
    13 Feb 2003
    thanks guys!!!
