News Windows XP will be phased out by 2008
Discussion in 'Article Discussion' started by Tim S, 16 Apr 2007.
  1. Tim S
    Tim S OG
    8 Nov 2001
  2. DivineSin
    DivineSin What's a Dremel?
    23 Apr 2004
    I think this is a damn good thing. Think about it for a second, Vista has bad driver and incompatibility problems. How do you solve this? By removing the old software from the market and making the companies better support their new product. From my point of view, Vista is a much better operating system, however it just suffers from being too new and Microsoft is actually doing something good to phase out XP. (MS, do good you say? :worried: )
  3. quack
    quack Minimodder
    6 Mar 2002
    At least they're not withdrawing support for XP just yet. I have no desire to upgrade to Vista this year (on my main PC that is), and probably not the next either.
    I have upgraded to Vista Home Premium on my HTPC however, it is so much better than XP MCE 2005.
  4. mikeuk2004
    mikeuk2004 What you Looking at Fool!
    3 Sep 2004
    Thats the power microsoft has. They are making sure you buy vista now. How will this work for business users.
    For example I work for the Goverment and we are only just being upgraded to Windows XP next week and reason for this??? Because Microsoft stopper supporting for NT Workstation.
    Business will still be using Windows 98 if Microsoft did not stop supporting it and provided security updates. Business's are not interested in Vista YEt and will be years before they buy into it.
  5. DougEdey
    5 Jul 2005
    I work for the government as well, and they believe that IE6.0 is secure.
  6. Darkangel
    Darkangel What's a Dremel?
    18 Aug 2003
    I thought it normal for them to stop selling theyre old OSs after a while. All theyve done is set a date. In a years time I imagine Vista will be sorted out virus/sp1/driver wise and everyone will be after it anyway.
    I for one, if building a new system, will be after the latest OS to go with the latest hardware.
  7. culley
    culley What's a Dremel?
    12 Jul 2006
    I remember hearing on a TWiT podcast awhile back that they will be still supporting updates and what not for atleast 5 years. I think ill stick with XP for a long time i still have 2000 on my laptop and my file server, i personally dont actually like Vista that much but to each his own.
  8. Bluephoenix
    Bluephoenix Spoon? What spoon?
    3 Dec 2006
    I think that Vista has a bright future due to its rewritten code, and that once the driver and compatibility issues are fixed (or alternatives are found) that it will eventually be seen as a turning point towards better design, even if a little bit of stability loss and some hardware upgrade costs were initially incurred.
  9. rupbert
    rupbert What's a Dremel?
    28 Jul 2002
    This is a good thing.
    Vista is a much better OS, and I'd much rather it be the sole focus of Microsoft.
    I think XP has been developed as much as is possible, and the much touted SP3 delays will probably lead to it not even being released.
    This is also a pre-cursor to the next OS from Microsoft (Vienna) which in my opinion will be released at the end of 2009. If Vista had a lower user percentage than XP at this time, they could not justify the release of Vienna and it would likely be delayed until 2012...
  10. wafflesomd
    wafflesomd What's a Dremel?
    22 Oct 2005
    I prefer my OS's to not use half of my ram while idling.
  11. rupbert
    28 Jul 2002
    Fair enough.
    But for me I want the OS to reflect the modern hardware it will be installed on. Otherwise we would still be using Windows 98...
  12. DougEdey
    5 Jul 2005
    wafflesomd: common misconception, more use is good. That's what it's there for. Windows can use what it needs whenever it wants, but it keeps as much data in memory as possible.
    Linux always has 99% RAM usage. Ask Glider.
  13. DXR_13KE
    DXR_13KE BananaModder
    14 Sep 2005
    i will buy vista as soon as i get a better machine, and i hope MS does not stop supporting XP soon.
  14. Bluephoenix
    3 Dec 2006
    RAM is there to be used, and the OS takes a back seat while running games, but takes the opportunity to run more smoothly when the RAM is open for use.
  15. Robotrix
    Robotrix What's a Dremel?
    11 Mar 2007
    Then they might as well skip XP altogether and upgrade straight onto Vista. Right...?
  16. wafflesomd
    22 Oct 2005
    Sooo
    Battlefeild 2 chugging along with 2 gigs of ram isnt the os taking up too much ram?
  17. rupbert
    28 Jul 2002
    No because even on XP Battlefield 2 chuggs with 2Gb of RAM, it's one of the poorest written engines I've seen in some time...
  18. GoodBytes
    20 Jan 2007
    God XP.... I sooooooo Hate it...
    It was fine before, but since I got my new computer.. installing XP is HELL.
    I have XP SP1 CD, and it doesn't like PCI-express and doesn't like SATA.
    What does that make?!
    -> Corrupt data non-stop (works like once very 10 times), until you upgrade to SP2.
    -> 16 color screen, until you pass the first set of SP1 updates. (then the video card works)
    And then well all is installed, you got to do to teh device Manager, go to the SATA controller device, and enable your HDD of read/write cache, so that your computer runs fast.
    Take about 1 day and a half to setup completely (including installing all applications).
    But with Vista... heck even Vista Beta 2 public release, that I tried... 18min, and poof your printer works, and your computer has no issues.
    After using Vista RC2 for many many months... and coming back to XP, and I can tell you, you start seeing XP bugs, and get on your serious nerves.
    Also, my applications starts at least 1.5-2 times faster. (Maybe because the OS has a better resource management, and proper multi-core CPU's support)
    This summer, (August) I'm going to be 100% Vista.
    If I would review Vista, I would give a 9.5/10.
    - Game ran slower (at the time) due to lack of official video card drivers.
    - No sound (at the time) due to lack of Creative X-fi drivers issue.
    Computer Specs:
    - Geforce 6600 GT 128MB of RAM PCI-e (will be replaced with an Geforce 8 series)
    - 2GB of RAM 400Mhz, form Corsair
    - ASUS A8N32-SLI (Nforce 4 16xSLI)
    - Western Digital SATA-II HDD 250GB.
    - Creative SoundBlaster X-Fi XtremMusic
    - Antec TruePower 2.0 480W
    - AMD Athlon 64 X2 4400+ S939
    - Latest system BIOS installed
    - Purchased Retail Windows XP Pro SP1
  19. Bluephoenix
    3 Dec 2006
    @goodbytes - I know what you mean, I have an XP CD with no service packs at all, and until I gave it the updates etc, it just wigs out big time.
    for my CAD box vista installed in <12min with absolutely zero issues :D
  20. Tyinsar
    Tyinsar 6 screens 1 card since Nov 17 2007
    26 Jul 2006
Tags: Add Tags
