Scratch Build – In Progress [Windrider] Shiny steel for charity -Finished and given away-
Discussion in 'Project Logs' started by La carotte d l'o, 18 Mar 2008.
  1. La carotte d l'o
    La carotte d l'o What's a Dremel?
    27 Nov 2007
    Thank you liratheal, alonso_bistro and DonT-FeaR.
    @ [ZiiP] NaloaC. Yeah, using newspaper is easy way to keep dust minimal, just turn page and you have clean working area.
  2. dream caster
    dream caster just lurking from out there
    1 Jan 2002
    Really nice work. Good to see it.
  3. La carotte d l'o
    27 Nov 2007
    Thanks dream caster.
    I noticed that thread is missing lots of pictures, seems that imageshack has removed them. I need to upload them again someday.
  4. Sethva
    Sethva What's a Dremel?
    12 May 2009
    This is such an amazing build. I love everything on it, the shiny goodness, the ultracool plexi, eye of detail and the incredible craftsmanship! I post my first post in your honour, Sir!
    *Subscribed*
  5. La carotte d l'o
    27 Nov 2007
    Thank you Sethva, much appreciate your words. Welcome to Bit-tech!
  6. La carotte d l'o
    27 Nov 2007
    Someone mailed me and asked how i polished those acryls. Sorry, for that i forgot to describe it earlier.
    I watersanded parts to 1200grit and after that i used this method, which i learned for Cheapskate: http://i204.photobucket.com/albums/bb255/cheapskate_02/Aug1-1.jpg
    In his project Blooballs: http://forums.bit-tech.net/showthread.php?t=134263&page=6
    Also i have noticed that you can use some wax for polishing after sanding, i have tested teflonwax and it works nicely.
    Easy method, but you can't use glue for those waxed surfaces.
    Wax works nicely with holes and other hardly reached areas and it also makes engravings little smoother and clearer.
    Teflonwax what i have used is mentioned to use in industrial assembling. So i don't know how it works with basic waxes.
    Update 13.5.2009
    I wanted to do some re-shapening for those side blades which i was done earlier.
    I mean those: http://img520.imageshack.us/img520/9904/hmis003.jpg
    So i tooked them to my work, this time i broked the rules and tooked camera with me.
    So, heres the tools what i have mostly used in this case:
    Not so shiny anymore, maybe i have spanked them too much.
    I started to make so shaping with corner grinder:
    Used depurring tool to shape those holes and corner grinder again:
    Some shaping with deburring tool:
    After that i continued at home with dremel.
    Now those blades are re-shaped, of course i will make some fine shaping during sanding. Tomorrow i'll take them to my work and use that orbital sander to sand them to 400 grit, after that, water sanding and polishing.
    That's how i have done all parts in this case. Those blades are coming one in both sides of the case.
    Sorry, that my english sucks again.
    Ps. My betting in ice hockeyworld championship tournament was all wrong. Final standings 1.Russia 2.Canada 3.Sweden 4. USA
    update 14.5.2009
    Shaping and raw sanding done, parts in their intended placements.
    Just posing though.
    I also started to make a cover for psu:
    Used left over piece of acid proof steel.
    Marked..
    and cutted.
    Used corner grinder with 1mm thick cutting disk.
    That weird mark in the middle is an "CenterLine", i take all measures in the middle, so i get symmetrical parts.
    And here is the part after bending:
    Looks stupid now, but don't worry its going to be actually kind of frame, i just needed to do some test fitting and measuring before cutting etc.
  7. La carotte d l'o
    27 Nov 2007
    Update 15.5.2009
    Some progress with psu cover:
    Did some cuttings with corner grinder:
    Smoothed curves with deburring tool:
    Did more cutting:
    and more and more:
    And smoothened with sanding thing seen in picture:
    Attached one 7mm wide slice with tig:
    And here's the tig i and my safety gears which i use also when grinding. Speedglass automatig welding mask and Adflo dust and gas filter.
    Welding done, that grey colour is oxidation, caused a little too much heat, allthought that isn't dangerous, but uggly thought.
    And rough sanding done, i will sand it better when i have done all weldings:
    You can see that its little twisted, thats usual when welding acid proof steel. That is easy to get straightened, but that's the reason why i have used mostly rivets instead of welding.
    Thats all for now, allthought that isn't even near to be finished, more with that someday in next week.
    And because i'm me, i won't even try to describe what im intending to do. (not sure do i know it either):D
  8. MIGUI
    MIGUI What's a Dremel?
    27 Feb 2009
    Good job. :thumb:
  9. The boy 4rm oz
    10 Apr 2008
    You really do have some very nice tools at your disposal. The same gear over here in Australia would cost anywhere from $5,000 - $10,000, depending on the brand you chose.
  10. La carotte d l'o
    27 Nov 2007
    Thank you MIGUI
    I think that the cost is here something similar, that welding mask costs near 500€ and those grinders 500-1000€ each, and that removable tig-welder is cheapest welding machine in our company (link is pdf) i'm happy that i don't have to buy them by myself. :D Allthought i should stop throwing my tools when i'm pissed. :(
  11. Cheapskate
    13 May 2007
    Are you building a Star Trek vehicle there? :hehe: Whatever it is it's really cool looking.
    I have no idea what you linked to. My Photobucket is down again.
  12. La carotte d l'o
    27 Nov 2007
    :D i'm going to do more shaping later, also those bendings are just to keep it straight when welding, i will cut them of later. Its also 10mm too high, i did it intentionally because its easier to cut of than add more.
    That link isn't important, just tool stuff and its also finnish so you would't get more than some pictures. Allthought we have nearly every kind of tool what modder would ever need, but those are just too big, cnc-mills with X=23 500mm Y=4000mm Z=1400 W=1200mm, working area isn't very usefull when trying to make small parts. :(
    I also got some parts today for Sindrom .
    Lapped E2160 processor and 2 x 1gb 800mhz muskin memories. Not killers, but free and i'm very gratefull for this donation, thank you.
  13. ringo
    ringo What's a Dremel?
    14 Jun 2008
    Your project fascinated me, really good job.
  14. talladega
    talladega I'm Squidward
    18 Aug 2007
    every update you amaze me with your awesome metal working skills.
    my recent battle with steel was cutting a 1/4" thick x 2" wide x 12" long bar in half down the center into two 1/4x1x12 pieces. I used a Dremel with EZ-Lock cutting discs. Used 2 discs to cut the whole thing. Work quite well. :D
  15. E.E.L. Ambiense
    E.E.L. Ambiense Acrylic Heretic
    26 Jul 2007
    :hehe: Sure looks like it too!
    Amazing work as always, man. It's a real one-of-a-kind mod.
  16. La carotte d l'o
    27 Nov 2007
    Thank you mates.
  17. DonT-FeaR
    DonT-FeaR I know what a fk'n Dremel is ok.:D
    23 Jul 2008
    wow nice use of a tig
  18. La carotte d l'o
    27 Nov 2007
    Thanks DonT-FeaR. I tried to draw somekind of picture to show what i'm intending to do, but my drawing skills are so bad that i think its just better to leave drawing and show it when its done. :D
    Allthought, im intending to add some curves more and some acryl parts too.
  19. [ZiiP] NaloaC
    [ZiiP] NaloaC Multimodder
    9 May 2008
    Taas kun suomalainen näyttä miten se tehdään! :thumb:
    Looking great as always. I envy people who have tools such as yourself, let alone the time and parts. I'm stuck with ideas....:grr:
  20. La carotte d l'o
    27 Nov 2007
    Kiitos, vielähän se on kesken. :)
    I think everyone has some reason to envy someone, i envy those persons who has lathe what to use or drillpress at home. :D
    I will continue that psu-cover at tomorrow morning, i'll post some pictures in the evening.
