Scratch Build – In Progress [Windrider] Shiny steel for charity -Finished and given away-
Discussion in 'Project Logs' started by La carotte d l'o, 18 Mar 2008.
  1. La carotte d l'o
    La carotte d l'o What's a Dremel?
    27 Nov 2007
    Thanks DonT-Fear.
    My intention was to make this kind of cutting for it:
    I used Paint, because i don't have l33t photoshopping skills.
    What do you think, because i'm not sure, should i leave it like that, or make that "window cutting"?
  2. DonT-FeaR
    DonT-FeaR I know what a fk'n Dremel is ok.:D
    23 Jul 2008
    both are pretty leet... i like em both
  3. La carotte d l'o
    27 Nov 2007
    Hmm. Any other opinions?
    5 hours time to say which is better, cut or no cut? Because i decided to get it finished in this week and today is only possible day to use better tools than dremel in this week.
    Cutting acid proof steel with dremel really takes loads of cutting disks and time. :blah:
  4. DonT-FeaR
    23 Jul 2008
    im concerend about strength but cut it if ur confident
  5. The boy 4rm oz
    10 Apr 2008
    It looks pretty good as stock but I really like the look of those extra cuts, the steel you used has a ton of structural integrity so I say go for it ;).
  6. La carotte d l'o
    27 Nov 2007
    I was thinking the same, and cutted it. I'll post some pictures when i have come back to home. Now i have to spend some hours at work. :thumb::rock:.....:eyebrow:
  7. Cheapskate
    13 May 2007
    Wild stuff.:thumb: Will you be welding the psu holder to the case?
  8. La carotte d l'o
    27 Nov 2007
    No. Half of the psu will be inside the frame and another half inside the case. Psu will be secured with some screws for the case and this frame should stay nicely still above the psu, because it should be quite tight fit. So it shouldn't need any securing, but that will be seen later.
    Here's the cutting for the side:
    Sometimes when you're making something, you might hear a little voice who whispers inside your head, "carefully, don't make scratches or you need to do some serious sanding..". Of course you know what you are doing, so no reason to listen that stupid voice. You can see those scratches in picture above, not big ones, but would definatelly look bad in polished surface. Little rushing with corner grinder means more time with the sanding paper.
    Another side:
    And the inside, not so beatiful, but it won't be visible at all.
    Posing:
    After polishing and psu inside, it should look quite nice.
  9. The boy 4rm oz
    10 Apr 2008
    The extended cuts really give it a completely different look, I dunno how to describe it lol but it looks good.
  10. La carotte d l'o
    27 Nov 2007
    Thanks 4 handed mate. My intention was to make some "shaping" and engraving for it, but i think i'll leave it like that, it looks much cleaner without any decorations which could easily be overkill. So, just a simple, clean frame for the psu.
    If i have time today, i will start to make a candle holder for the webcam.
  11. DonT-FeaR
    23 Jul 2008
    yeah that deffinately looks better.. great work!
  12. La carotte d l'o
    27 Nov 2007
    Thanks DonT-FeaR! I'm still thinking should i do some shaping for it?
    Again i show my l33t skills with paint :rock::
    ^ That is one reason why i don't use 3d-models to show my plans, you just don't want to see them. :)
    Those white spots are small cuts, little something like as an saw blade.
    I think they might fit for the frame, what do you think?
    E:
    I did some candle testing:
    Don't know does it look like an candle or something else instead. :naughty:
    But, that was just made for practise.
  13. La carotte d l'o
    27 Nov 2007
    28.5.09
    Small update:
    I made an backplate to attach psu to the case.
    First i marked the cutting lines and holes for the screws:
    When drilling acid proof steel, is recommended to use some cooling to prevent strain hardening.
    I use Fuchs cutting spray for that.
    After drilling i did countersunks with bigger drill:
    Then i started cutting. You might see that i don't broke the line, is more accurate to cut beside it.
    After several cuts i got some pieces of:
    Did some raw shapening with the edge of flapdisc:
    And finished corners with that round sanding thingy, which name i don't know:
    Before final cuts i did some sanding, because its more easier to hold bigger plate than small:
    And there's the part before watersanding:
    I have also started new modding project. Don't know should i make own work log for it, because its going to be quite basic.
    That's all folks.
  14. MIGUI
    MIGUI What's a Dremel?
    27 Feb 2009
    Amazing.
    You work very well on metal. :thumb:
  15. The boy 4rm oz
    10 Apr 2008
    I believe the "round sanding thingy" is called a sanding drum. The PSU back plate looks very nice, almost like a Lian Li one, except shiny ;).
    Yeah why not, make another worklog for this new project, it will be interesting to see what you have up your sleeve for this one.
  16. La carotte d l'o
    27 Nov 2007
    Thanks MIGUI!
    Sanding drum, i try to remember it. Thanks.
    Yeah, i used on Lian Li backplate as a model, so similarity didn't come accidentally. :)
    Next project is going to be quick, "car-mod" for a friend. I'll make new thread when i have done something more than ripping it off.
  17. DonT-FeaR
    23 Jul 2008
    hey.. that looks fantastic.. your really good at this metal work :) keep it up.
  18. La carotte d l'o
    27 Nov 2007
    Thanks DonT-feaR!
    E: I have used this whole day to sand that "windriders" psu-frame and didn't even get it finished: [​IMG]
    I should kick myself for making those scrathes.:wallbash:
  19. La carotte d l'o
    27 Nov 2007
    Psu-frame sanded and polished:
    It really took some time, nothing else done.
    No updates for a week or two, job takes me out of country tomorrow morning.
  20. DonT-FeaR
    23 Jul 2008
