Scratch Build – In Progress [Windrider] Shiny steel for charity -Finished and given away-
Discussion in 'Project Logs' started by La carotte d l'o, 18 Mar 2008.
  1. yeknom
    yeknom What's a Dremel?
    23 Apr 2008
    wow that looks incredible in its entirity
  2. La carotte d l'o
    La carotte d l'o What's a Dremel?
    27 Nov 2007
    Thanks yeknom.
    Some pictures more:
  3. ringo
    ringo What's a Dremel?
    14 Jun 2008
    great case, cool clean and shiny look. You did a great job.
    La carotte d l'o likes this.
  4. La carotte d l'o
    27 Nov 2007
    Thanks ringo, much appreciate your words.
    Another side is still unfinished and i will add some little decorations around the case.
    Here's the table before watersanding, simple as hell. I thought i keep it and save the laser cutting for the next project, allthought i need loads of parts for that.
    I'm not 100% satisfied for this side:
    First i liked the idea of showing components, but now i think that mb and gfx are too visible, needs to do something for them. Also door needs some stripes or curves to get it fit for the "theme".
    I'm still trying to get this case done within 2 weeks. (starting now)
    sorry my bad english.
    Javerh likes this.
  5. Javerh
    Javerh Topiary Golem
    5 Sep 2006
    I have to agree. The other side is plain awesome, but the window side is just plain. Go wild and show off your mad metal skills! :dremel:
    Good luck with the two weeks. I still have an exam on Monday, but after that I'll also start a mad dash. I look forward to seeing this thing live.
  6. MIGUI
    MIGUI What's a Dremel?
    27 Feb 2009
    Nice work my friend. :thumb:
    Excellent.
  7. ModMinded
    ModMinded Are you throwing that away?
    26 Aug 2008
    Very impressive work!
    I'd agree that this side could use a little embellishment, considering the awesomeness of all the other panels. What about continuing the web theme onto this side as well? It would go well with the cool horse. I'm sure you could make a fantastic mobo cover / gfx cover, but the time involved might interfere with your other plans.
    I think the table suits the case very well!
    Where do you want to have the switches?
    +rep n stars.
  8. La carotte d l'o
    27 Nov 2007
    Thanks ModMinded, Javerh and MIGUI.
    I'm goin to make a little case for the dvd-player, usb hub and switches to be placed to the desk. I'm going to sleeve cables together, so there's only one little bigger cable between case and "deskbox".
    I'm going to use this kind of connectors for the switches.
  9. DonT-FeaR
    DonT-FeaR I know what a fk'n Dremel is ok.:D
    23 Jul 2008
    looks fantastic mate.. excellent work
  10. Javerh
    5 Sep 2006
    One big cable harness is a good idea. How are you planning to separate the cables so that it looks nice?
  11. La carotte d l'o
    27 Nov 2007
    I haven't decided yet, needs to make some testing first.
    Quick question. Because i'm colorblind i need some help to be sure. :(
    Are these 330 Ohm resistors?
    I'm going to add some leds for the fans.
  12. Javerh
    5 Sep 2006
    Orange-Orange-Brown-Gold, so yeah they're 330ohm 5%.
    ModMinded likes this.
  13. DonT-FeaR
    23 Jul 2008
    winner /\
    but i thought gold was 10% and silver was 5%??? idk lol
  14. La carotte d l'o
    27 Nov 2007
    Thank's a lot for the help guys.:thumb:
    Being colorblind is really annoying sometimes.
  15. DonT-FeaR
    23 Jul 2008
    :O
    thats why everything is pollished aye?
  16. La carotte d l'o
    27 Nov 2007
    No and maybe, i also like polished surfaces. But that's the reason why i may talk about blue parts when showing green ones. :)
    Green and blue looks same to me, so i can't actually say how those colours fit together or trying to get some colours to "fit" together gives me really different impression than most of people.
  17. DonT-FeaR
    23 Jul 2008
    oh ok then :p
    well i would call it the wrong name anyway so it doesnt mater
  18. La carotte d l'o
    27 Nov 2007
    Did something today:
    Small accurate cuts in the doors with angle grinder.
    Now power cover is same level with the doors.
    Its allways good to protect polished surfaces when you're making cuts. I used masking tape and my left hand for that. :)
    I also remembered that i did this kind of part earlier:
    But i have lost it somehow. :( What do you think, should i make a now one to be placed under "windrider" (horse)?
  19. Javerh
    5 Sep 2006
    A new part of that type could be nice. You should try to shape it so it highlights the horse.
  20. DonT-FeaR
    23 Jul 2008
    hey at least the surface is not scuffed :p
