Scratch Build – In Progress [Windrider] Shiny steel for charity -Finished and given away-
Discussion in 'Project Logs' started by La carotte d l'o, 18 Mar 2008.
  1. La carotte d l'o
    La carotte d l'o New Member
    27 Nov 2007
    I sanded those plates with machine before bending to 120-150-180-240-320-400.
    After bending i sanded with my hands to 400-500-600-800-1000-1200 and finally polished with autoclym metal polisher. It's not actually hard work, but it takes time.
    Mainthing is to use a lot of water, if the paper is too dry it's get stucked and it makes visible cratches. If you sand 400 grit to vertically, you must sand 500 grit horizontally.. etc. You can see the colour of the plates changing when you are sanded enough. Before changing paper, every scratch has to be sanded down.
    Those final, 1000 and 1200 i sanded under the shower, it makes better surface. Mainthing is that there is no shortcuts, you can't jump 400 to 1200, every scratch that 400 paper left is still visible.
    With alumine needs to go to 1500 or higher, but you can make bigger "jumps" 400 to 600-800-1200-1500 grit, and finally maybe some sandingpaste, then polishing. (if you don't wanna see any scratches:)
    And, thanks for comments. :)
  2. BigPoppaJNutZ
    BigPoppaJNutZ Beyond the Dremel...
    14 Feb 2008
    It's starting to look really nice!
  3. Cheapskate
    13 May 2007
    That fan is a finger-eating nightmare! I like it! If you can power it with brushless ac it will be deadly.:D
  4. Burnout21
    Burnout21 Is the daddy!
    9 Sep 2005
    AC power would limit him to 3000rpm, you could go much faster with DC!
  5. rls669
    rls669 i can has dremel?
    15 Mar 2008
    That's how I polished my steel panel, but I'm having trouble with alum angle. It's too narrow to sand across it easily and it takes a lot longer to get all the scratches out when all the sanding is in the same direction.
  6. Macros_the_Black
    Macros_the_Black Yup.. I'm a f-ing reptile
    7 Jul 2007
    Looking sweet! Ooo, I love those "wings" on the fan!!! :rock:
    Keep it up!
  7. jhanlon303
    7 Sep 2006
    PLEASE NO PICTURES OF THIS! This is a family forum :D:D:D:D:D:D:D
    John
  8. La carotte d l'o
    27 Nov 2007
    Damn, should i post some pictures for my gf in shower instead? :)
    Here is better explanation for the fans i'm going to make:
    I will power up them, using power rails. I'll make center for the fans using polycarbonate to insulate those leafs, wich i'm going to use as power rails. So i can dump that pipe, and no visible wires.
    Power rail is going to be between two polycarbonate layers, wich i'm going to use as a backpanel.
    I hope you understand what i'm going to tell. Sorry for my bad english, i suck in every language, so don't care about it. :D
    And thanks for the nice comments!
    Ps. Now i have a name for the project: Windrider
  9. Macros_the_Black
    7 Jul 2007
    Cool! Plz, post detailed pics of this when it's done!! ^_^ ..ehm... of the fan that is.... the gf pics you can pm to me. ;P XD lol
  10. Jipa
    5 Feb 2004
    Good work all the way, I saw your last project in the Allthemods, but this might be even better than that!
  11. La carotte d l'o
    27 Nov 2007
    I'll hope that this is going to be better, as i have no time limits this time, and i have actually made some planning, so maybe i won't be "jumping" so much this time. :idea:
    And actually, most idea's for this case i got when i made that -Cold steel- project.
    Here's a pic for that:
    This one is going to be better version of that.
  12. jhanlon303
    7 Sep 2006
    That one really is trash. I'll PM you my address and you can send it to me. :D:D:D:D:D:D
    John
  13. La carotte d l'o
    27 Nov 2007
    Sorry, i gived it for my son as a christmas present. That's the reason why i have time limits when i was doing it.
    But i have some other junk to be delivered, let me see... :D
  14. Burnout21
    9 Sep 2005
    i feel sorry for your son, every day he will see your case and think, dam he gave me the crap one! so shiney i want!!!
  15. BigPoppaJNutZ
    14 Feb 2008
    Agreed, you could just do him a favor and send it to me. I will carry the burdon for you, lol.
    Great work! I would love a case like that. Very clean looking. Shiny is very good!!!:D
  16. rls669
    15 Mar 2008
    This forum is just full of humanitarians :D
  17. Scirocco
    Scirocco Boobs, I have them, you lose.
    3 Jul 2007
    It's certainly full of something! But that's all I'll say since this *is* a family forum. ;P
    Pretty, shiny goodness on this case, btw. Very much enjoying your work and updates so far.
  18. La carotte d l'o
    27 Nov 2007
    Thanks guys.
    This is not actually an update, but some pictures.
    Those parts are green uv-reactive plexi. Now i will make holes for the i/o-shield etc.
    I also made two pieces for the backpanel, but the maskintape what i used, was really terrible. So ihave two pieces of polycarbonate full of glue. :( (i'll never buy cheap maskintape again.)
  19. Burnout21
    9 Sep 2005
    may i mention hot water and washing up liquid, and plenty of elbow grease, that soon shift the glue.
  20. jhanlon303
    7 Sep 2006
    Look for tape marked painters or low tack - less glue and easier to remove In the US I use 3M Blue tape. You will have to translate labels since I have no Finnish Good luck, looks sweet
    John
