Hey all. Recently i bought this card and its great, i can watch different channels to my actual TV, pause live TV and record. However when i set a recording for say, when im out and i leave my PC on...it doesnt work properly. I tested yesterday a number of times whilst i was there just for a few mins to see if it worked but it didnt really....it kept recording 2 second clips of the show, and at the end of designated recording slot it had saved about 50+ 2 second clips of the show. Normal recording works when you just hit the button, but when you program a time and channel in to record it doesnt work properly. Anyone have any ideas?
I got it working. I started reading the instructions because i wanted to know if i could rearrange my channel order because its all over the place...and came across the settings for recording. I was using the default settings which should work, i looked at the picture in the manual and the settings were slightly different so i changed mine to the same, and it worked. Strange how the default doesnt. Anyways, dont suppose you know if its possible to rearrange the channels? Also some of them dont come with the logo of the channel on the guide....just wondering if you can save an image file and use that somehow? Thanks
No idea, never been able to rearrange the channels in either DVB cards ive used, although ive not used a winfast card.
Its annoying because i prefer them in normal order. Channel 5 is half way down the pecking order on the list.
