Scratch Build – Complete ⭐ WING X99 - A CNC-milled Scratch Build! (Benchmarks,temps and wallpapers posted)
Discussion in 'Project Logs' started by Andreas | Brodholm, 19 Aug 2016.
  1. Nexxo
    Nexxo Rotate Your Owl For Science
    23 Oct 2001
  2. Nexxo
    23 Oct 2001
    I need your CNC, your bender and your workshop.
  3. Andreas | Brodholm
    Andreas | Brodholm Minimodder
    12 Jan 2013
    Next update! I am a bit behind on editing, but I am working to get them out. Due to the nature of the CNC the process it is pretty much the same all the time. So I will not describe the process each time for each part. I catched myself writing the same things over and over :D
    If you have any questions feel free to ask :)
    This update I am making the back frame of the case!
  4. eucalyptus
    eucalyptus I am 19 and Swedish!
    29 Sep 2015
    I suppose there is beginners, good modders, great modders, incredible modders, and then somewhere far above them all in a class for himself I believe you fit very well.
    This is just unreal. I believe surreal is the correct word!
    Andreas, if people in this thread is jealous of your workshop, then you know it's some magical stuff you have there ;)
    In Swedish,
    Helt jävla sjukt vackert!
  5. Andreas | Brodholm
    12 Jan 2013
    Thanks! more progress!
    Top frame that will hold the plexi glass and a cover fastened with magnets.
  6. p0Pe
    p0Pe gief cake?
    23 Nov 2007
    The want is real...
  7. bagman
    bagman Minimodder
    18 Apr 2009
    This is some next level ****. Sometimes you just have to sit back and watch the magic.
  8. Andreas | Brodholm
    12 Jan 2013
    :thumb:
    :D Yeah, its amazing to have access! Worth all the effort in the end :thumb:
    Thanks mate, just sit back and enjoy! More things coming soon!
  9. Andreas | Brodholm
    12 Jan 2013
    Left inner frame of the case. Each part is so much work. Slowly but surely I am getting there. Had a bit of a mishap with this though, but redoing it will be easier.
    Last thing that happened is that it started to chatter. Did not design this very good. It is very difficult to clamp this down. Will have to redo this part... This mistake costs about 4-5h of work wasted. Not very fun nor motivating but I do not have much of a choice.
  10. Andreas | Brodholm
    12 Jan 2013
    Same as before, but this time its the right side :)
  11. Cheapskate
    13 May 2007
    So many people touching themselves inappropriately in here... :lol:
  12. Andreas | Brodholm
    12 Jan 2013
    hehe :D
    :thumb:
    More pictures soon!
  13. Hukkel
    Hukkel James' minion
    20 Dec 2012
    You hereby get fined for posting explicit material in this thread!
    Your fine is 1 awesome CNC. I will send you my address over PM.
  14. Andreas | Brodholm
    12 Jan 2013
    damn! BRB 2 years, need to build a new one :waah:
  15. Andreas | Brodholm
    12 Jan 2013
    The time has come to do probably the part I was most worried about, the front of the case.
    Test piece
    Clamped down
    Same width as the real piece. Needed a large amount of force on this. Had to get help, I was to light weight so I lifted myself...
    Really pleased with the results on the test piece.
    Making the actual sized part
    Made two while I was at it.
    Same length piece bended to insure that the length between the bends was correct. It was of about 0.3mm or 0.012 inches for you metric fellas! Very pleased with the results and I will not be able to get it much better than that
    Final piece bent and done! Did not take any photos during this since we had to be two people checking and bending at the same time. Did not want to ruin the piece just to get some pictures. Same procedure as before, just with the correct sized piece.
    Really good bends, very close to 90 deg if not perfect.
    Ended up about 0.2mm of the real measurement. So I am very happy with that. I decided before that 0.5mm would be good, around 1mm would be okay and 1.5mm and I would redo it. This measurement does not matter that much since the plexiglass sides could be made slightly of angle and you never notice a 1mm change in height over half a meter.
    The front now needs to be machined to fit. First up is some covers though!
  16. Andreas | Brodholm
    12 Jan 2013
    Is there any way to turn of scaling on the pictures? The scaled down versions is awfully small. Even imgurs "huge" 1024pix sized gets scaled, and the smaller version of imgur does not fill the page here on bittech.
  17. Cheapskate
    13 May 2007
    I would have thought the weight of your massive testicles would have been sufficient.
    -I apologize if that doesn't translate as a compliment in Swedish. :worried:
    Bend is awesome. There's no tool scars! It's like magic.
    Pic resize: Yeah, Your stuck with it. The amount of phone users that surf here make it a requirement.
    Trust me, though. We are clicking the yellow bars. :D I have noseprints on my monitor too.
  18. Andreas | Brodholm
    12 Jan 2013
    Thanks for the info. I guess it is not too bad. Would be nice with a option in the user cp though to have resizing turned of :thumb:
  19. Andreas | Brodholm
    12 Jan 2013
    Making these covers to hide screws and unwanted things. They will fit stay put with magnets if everything works out.
    Here you can see the spring when milling down to 3mm from 8mm. Should really get some 3mm sheets. Had to bend it for a good 20 mins to get it straight.
    A very snug fit. Really pleased!
    Milling the top cover here.
    Same procedure as always, rinse and repeat!
    Done! The "final picture" of the top was very out of focus. Turned out great and fits nicely over the top part. Also had to do some manual forming of this since it also had some springback from inner tension in the material (I am guessing that's it)
  20. Cenedd
    Cenedd What's a Dremel?
    10 Oct 2016
    When it said "Scratch build" I really wasn't expecting you to be making the tools to make the build! That's taking it to a whole new level....and well by the looks of the results! The only problem is that I now can't touch another piece of metal....because I'll just be embarrassed by the results!
