Linux WinXP on Linux PC
Discussion in 'Software' started by FaIIen, 15 Apr 2007.
  1. FaIIen
    FaIIen origami killer
    31 Dec 2001
    For this Sunday morning I'm planning to install WinXP to my Linux PC. Mainly for games, nothing more. Ubuntu is on the first SATA drive. I was thinking I could resize the partition of linux (boot cd -> gparted) and make a FAT32/NTFS partition on that same SATA drive and then install windows in there? Do you think there will be any complications ? Off course Windows will erase my current MBR but I can restore it later using my Ubuntu boot cd or smth. Any tips are welcome. :geek:
  2. DougEdey
    5 Jul 2005
    I'd say, grab a cheap 2nd drive, install windows to that, then tell grub to boot it.
  3. FaIIen
    31 Dec 2001
    i did what you suggested. I've unplugged all my disks exept the 40gb IDE where I installed winXP. Now I go back to linux in order to edit my grub menu.lst so i can boot Windows. This is the order of my drives
    hd0 (sata) Ubuntu
    hd1 (sata) stuff
    hd2 (IDE) WinXP
    hd3 (IDE) stuff
    the entry for my grub is
    title WinXP
    map (hd0) (hd2)
    map (hd2) (hd0)
    chainloader (hd2,0)+1
    When i try to boot windows I get "NTLDR is missing" :confused:
    If I change the boot order with IDE being first, windows will boot normally, overiding grub off course.
  4. Shagbag
    Shagbag All glory to the Hypnotoad!
    9 Nov 2006
    Does this GRUB entry work:
    title WinXP
    map (hd0) (hd2)
    map (hd2) (hd0)
    chainloader +1
    If not, does this work:
    title WinXP
    map (hd0) (hd2)
    map (hd2) (hd0)
    rootnoverify (hd0,0)
    chainloader +1
  5. FaIIen
    31 Dec 2001
    i fixed it by positioning my IDE 2nd on boot order.
