Windows WinXP Services
Discussion in 'Software' started by Moreland, 24 Feb 2003.
  1. Moreland
    Moreland banned
    16 Jan 2003
    i need to completely remove a service in winxp, not just disable it i mean completely remove :D
    I know where the services manager is in xp, but it doest give me the option to delete, only disable.
    If you can help please do, registry paths would be useful :D
    Thanks,
    P.S i have tried google but its late and im tired
  2. Jaz
    Jaz Banned
    18 Dec 2001
    why?
  3. Moreland
    Moreland banned
    16 Jan 2003
    cause im playing around trying to install mysql and i cant cause there is already a mysql entry in there, but its not connected to anything it just an empty service.
    So how do i get rid of it, i cant currently install mysql cause it says service already exists
  4. bee2643
    bee2643 What's a Dremel?
    7 Mar 2002
    and why cant you use the one thats allready there?
    MySQL is automatically installed with windows, that option i believe u cant uninstall, only disable it
    i could be wrong:rock:
    why not just work with it?
