Windows WinXP - uninstall useless stuff
Discussion in 'Software' started by sinizterguy, 6 Oct 2002.
  1. sinizterguy
    sinizterguy Dark & Sinizter
    25 Jul 2002
    Is there any way to uninstall all the useless bloatware that is bundled with win xp pro ? like msn messenger and the windows movie maker ?
    Any guides as to how to do it. or programs to unistall it ?
    Thanx
  2. Kevo
    Kevo 426F6C6C6F636B7300
    9 Sep 2001
    You can use XPantispy to get rid of MSN messenger.
  3. yodasarmpit
    yodasarmpit Modder
    27 May 2002
    Dont know if getting rid of it will be the same - but when I dissabled messenger it took ages to load up Outlook.
  4. sinizterguy
    25 Jul 2002
    Don't use outlook express/outlook either ... would get rid of it too if I could
  5. sinizterguy
    25 Jul 2002
    Thanx, downloaed xp antispy and changed some of the settings and removed msn messenger.
    Now got to figure out how to remove windows movie maker. and also outlook express if possible ... but I think that its impossible.:wallbash:
  6. Kargin
    Kargin Overdose . . .
    18 Sep 2002
    Remove it the good old fashioned way:
    Go into your directories and just tear it out. Remove it's existense form your system manually in every instanse. I do this and it doesn't do any harm (I use win2k though, I remove the bits I don't want)
    I would think it'd be fine with XP, if XP is as good as Microsquat bloats about it :rolleyes:
    *cough*Linux*cough*
    Other than that, might a third party de-installer or system cleaner maybe be able to do it? Like Norton Cleaner it's called maybe (I don't know the program really, maybe I'm talking out of my sitting organ)
  7. sinizterguy
    25 Jul 2002
    So you just browse over to the directory and delete it ?
    And it wont bugger my xp installation ?
  8. Morphine
    Morphine weeee!
    23 Feb 2002
    whats so bad about outlook express? I use it, simply because my ISP's email blows, but its free (dad pays for cable) that and id rather press one button in my quicklaunch bar insteadof going through literally 7 pages just to read my email.
  9. Kargin
    18 Sep 2002
    Firstly, don't hurt me if it does b0rk it up, if you don't feel confident about it, DON'T DO IT.
    That said, it shouldn't bother with it, obviouslt don't go deleting your systme files, but otherwise it's been my experience that it doesn't bother with it.
    My one friend who has experience with XP has basically stripped and hacked up his XP to all high heaven, he has almost nothing that isn't a system file, and it works fine. Doing a little google search on removing Windows XP bundled software might also help you.
    I am also a person who throws around OSes, I install my OSes so much it isn't funny, but that's mainly the fact that Windows hates me and tries to kill me by kamikaze diving into my face, so I usually just tear through things to figure them out and find out what I can do before I break it. Take this into account. If Windows uses it for something, then don't remove it, if you never use it, and you never see Windows use it (check your prossesses, services, etc) then chances are, it's safe to remove.
    Like I said before though, if you don't feel confident in what your doing, or don't want to chance having to re-install your OS, and are one of those people whom it would be very difficult or a giant pain in the rumpus to do, then don't do it.
    My two dimes worth :p
  10. sinizterguy
    25 Jul 2002
    Nothing wrong, it's just that I used to get my yahoo mail in outlook until they messed it up ... now I cant be bothered with it, cos I get all my other mail in yahoo.
    @Kargin
    Thanx...
    Do you think you could get you friend to do a guide or something ? :D
  11. Kargin
    18 Sep 2002
    I'll try contacting him, he's kinda hard to get a hold of.
    You should Winguides as I know he used some the info there, as have I to bualate Windows.
    WinXP Fix might be a place to check to, I dunno if it's any good, looks like it migth have a bit of info though.
    Okay now Windows, let's try posting this time without crashing.....
  12. Kargin
    18 Sep 2002
    MSConfig is another useful one to remove/change things, couldn't rememeber the name of it before, but he reminded me.
    Also he formated and is in win2k now. He tried going to far. He finally snapped Windows' little back.
    He also didn't record anything he did, and doesn't remember most of what he did. He said that most of it was from the regedit site (see previous post) and MSConfig and Tweak UI though.
    My advice would be to look through the websites, get MSConfig, and Tweak UI (both free, just googlealize them) and if your up to it, just go into where the movie maker (and any other programs you don't want) arre installed and just delete them if you want to try that. Your bst bet if you do try, is to instead of deleting them, move them and rename the root folder of the program (ie "movie make v90" renamed to "windows puking on my drives") and then reboot, if it buggers up Windows, rename it back and move it back (you might have to safe mode boot for this) and if it works, then permanently delete it.
    Sorry I couldn't be more help, hope that helps you at all though, and you somehow get XP to how you want it:D
  13. sinizterguy
    25 Jul 2002
    Thanx a lot ...
    I'll try to find stuff in the meanwhile.
    Hope you can get through to him :D
  14. Kargin
    18 Sep 2002
    I did get to him. Read the post just above yours, he broke his installation, he tried going to far (something both of us are famous for, unfortunately) and well, I explained it up there ^
  15. dylman
    dylman What's a Dremel?
    19 Aug 2002
  16. nesbit37
    nesbit37 Guest
    http://www.tweakxp.com
    that will have all the info you need to remove any useless junk and improve the performance of xp. If you are uncertain of your skills in doing any other things listed there (particularly registry editing) then don't mess with it unless you are willing to format if you mess it up.
    -Nesbit
  17. yodasarmpit
    yodasarmpit Modder
    27 May 2002
    TweakXP, great site - just got rid of MSN Messenger with no side effects
    Just type RunDll32 advpack.dll,LaunchINFSection %windir%\INF\msmsgs.inf,BLC.Remove in the run dialogue box and reboot - gone.
  18. scoob8000
    scoob8000 Wheres my plasma cutter?
    17 Feb 2002
    install windows 2000 :p
    in my opinion, it is XP without the eyecandy and added bloat..
    -scoob8000
  19. nesbit37
    nesbit37 Guest
    That may be true but windows support for win2k (for what its worth) won't be around too much longer. That of coarse means that software and hardware vendors won't be too happy catering to it anymore either. True more business use 2k then xp at the mo, but I believe even more are still using NT which is being completly nixed by MS at the end of this year if I remember correctly.
    -Nesbit
  20. Kargin
    18 Sep 2002
    Avoid all those problems:
    Install Linux:naughty:
    Ahhh.. Good old Linux... I'm back home.........
    And yes I was Redhat. I'm a whore.
