Planning Wire For Extensions?
Discussion in 'Modding' started by Zentaaa, 30 Jul 2014.
  1. Zentaaa
    Zentaaa What's a Dremel?
    23 Jul 2014
    I know I have posted this in the wrong place -_- Mod please move this thread to where it belongs please :)
    I am planning to make my own extension cables for my psu and I just need to know what is the wire used in the middle and where can I get it in the uk? Thanks :thumb:
  2. ferret141
    ferret141 Minimodder
    18 Oct 2010
    The middle wire inside the cable, yellow and green? Or the cable between the PSU and the plug socket?
  3. Atomic
    Atomic Gerwaff
    6 May 2002
    I used 18AWG wire when I made an ATX extension last.
  4. Big Elf
    23 Apr 2009
    You're looking for the metric equivalent of 18AWG of 24/0.2 (it's actually a narrower diameter but still within specification). Maplins sell it although it's overpriced but handy for small quantities.
    I use Rapid 01-1100 and this 01-1145. It is 2.3mm in diameter so 'trains' better when sleeved.
    If you want slightly thinner insulation then Farnells White and Black at 2.05mm thick are good.
