Motherboards Wire glue to repair damaged mobo tracks/traces?
Discussion in 'Hardware' started by llb443, 4 Jun 2010.
  1. llb443
    llb443 Assassins do it from behind.
    23 May 2010
    I have never used wire glue, I have never seen it, I only just found out about it today... I am wondering if anybody has worked with wire glue.
    Do you think that you could use it to repair damaged/cut tracks on a motherboard. In my case i would have wanted to use it to repair, 5 tiny tracks all cut, similar to this:
    This shows 3 damaged tracks, but I had 5 damaged tracks
    Would it work if you smeared the glue all over the 5 traces, waited for it to dry, and then cut the glue (with a razor or something) to once again seperate the traces from eachother? but like I said, I have never worked with wire glue. will it be able to cut that finely, or will it start flaking or cracking?
    any info or links would be nice...
    as always, thanks in advance, LLB443
  2. JaredC01
    JaredC01 Hardware Nut
    24 Nov 2002
    Personally I would scrape the traces then steal a wire from an 80-pin IDE cable and solder the connections back... Never even heard of wire glue, but I can't imagine it would last long-term.
  3. alpaca
    alpaca llama eats dremel
    27 Jan 2009
    see those convolutions on the other traces? that's done like that so the resistance and capacitance of each track has to be just right. If you repair those broken ones(with any method) you would alter the resistance/capacitance of those wires. if you're lucky, it wasn't critical. if you're not, your board is already done for.
    so my advice: go nuts. the only thing you could do is save it.
    oh: with the glue: cut it with the razor when it isn't dry yet, that way it won't crack.
  4. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    Aren't most motherboards multilayer thought? So if its a chunk like that one it may damage the underlying layers..?
  5. Bakes
    Bakes What's a Dremel?
    4 Jun 2010
    That's my concern, Bloody_Pete.
    The traces are one thing, but when it's dug through you might be a goner. The best you can do is have a go, since the warranty will be completely void.
    From reading your post, it seems as if that isn't your motherboard. If you don't have the huge chip, you could have a go with a conductive pen. This would probably be easier. Unfortunately, I think you also implied that you do have the big chip. This makes me want to ask - How did you manage this?
  6. llb443
    23 May 2010
    This is an Xbox motherboard, and this picture shows a common problem; whereby people damage their motherboards while trying to remove the X-clamps. This has to be done, with a small screw driver, reasonable force, and evidently a bit of delicacy. See below:
    All it takes is a little slip, and there you have the chunky dent... However, I bought an Xbox used from ebay. It came with a chunky cut, slightly bigger than the one shown above.
    What is a conductive pen, and how can it help me?
  7. Krikkit
    21 Jan 2003
    A conductive pen has some kind of tiny metal shavings suspended in a light glue to make, as the name suggests, a line which is conductive when you draw on the board. You can sometimes repair a broken trace on a mobo with it, but it's certainly not guaranteed.
    If the trace carries too much current the conductive line will likely just burn up because it's such a small amount of metal.
  8. Bakes
    4 Jun 2010
    Conductive pens are great for bridging gaps. They're widely used for volt-mods and the like, where bridging gaps can change the voltage applied to graphics cards.
    You could try to 'draw' the traces back on with a conductive pen, going around the problem to avoid it. If you're lucky, it will work fine. If you aren't, it won't and it could cause some further damage. Damaging a broken Xbox further might not be such a large problem for you, though. I'd probably find a conductive pen easier to use than glue, if only because pens are easy to use :D
    I googled and found this thread from someone with a (I guess) similar yet not identical problem: http://www.team-xecuter.com/forums/showthread.php?t=54054
    Hope you find it useful.
  9. TheBlackSwordsMan
    TheBlackSwordsMan Far over the misty mountains cold
    16 Aug 2009
    It's only an Idea, but back in the days, a friend of mine did a bridge with a hard-lead pencil. It was a Duron 2.4 if my memory is not at fault. Maybe it can work on Motherboard
  10. llb443
    23 May 2010
    so it sounds like conductive glue has been around for a little while, and that it now comes in pen form? I was mainly asking into the nature of the wire glue, but now I guess that doesnt matter. cos if i ever need to use it, i will just try a pen... has anyone actually used one of these pens? just from the sound of it, it seems like it would need a few layers?
    and did the pencil guy, use the lead to draw a conductive line? or did he just use the lead?
  11. TheBlackSwordsMan
    16 Aug 2009
    He used the lead to draw a conductive line. Back in the Day it was to unlock the Duron Coef XD
  12. Elledan
    Elledan What's a Dremel?
    4 Feb 2009
    Reminds me of removing/installing HSFs on old mainboards with the clamp-around-ZIF-socket method which required one to push a screwdriver aimed straight at a fragile part of the mainboard :)
    I used tough cardboard or a piece of thick plastic back then to prevent any mishaps. I would think that such a thing would be useful to prevent damage in this case too?
  13. llb443
    23 May 2010
    Yeah, I have removed these clamps successfully numerous times before... all it takes is a little bit of patience... it does get a bit annoying when you are trying for like ten minutes... it makes you want to just stab it... (I just go and make myself a cup of tea, and cool down for a while... and i havent had such a mis-hap yet)
