wired to wireless USB
Discussion in 'Hardware' started by leftkidney, 14 Jun 2008.
  1. leftkidney
    leftkidney Experienced Modder
    14 Jun 2008
    so simply put I want to take a wired USB device like a Keyboard (I know they make wireless ones but I want to do this) or something like that
    I know this can be done it is just about the radio transmitter needed
    Bluetooth will also work fine
    so again simply put I want to make a wired USB device Wireless - I will supply power via batteries I am just looking for where to look fot the things needed
  2. mm vr
    mm vr The cheesecake is a lie
    18 Nov 2007
    That is going to be so difficult and expensive that I recommend just simply buying a wireless one...
    And also the question about supplying power... How about batteries? No, because there is no way to get 5V from ordinary batteries :idea:
  3. leftkidney
    14 Jun 2008
    like I said not a problem it can even cost me $100 USD I dont care - and power not a problem
    I know how to get any amount of power from batteries so long as it is lower than the amount of power you have, like 2-3volt lion batteries is 6volts I can lower that to 5volts easily - you must not know a lot about powering things
  4. Splynncryth
    Splynncryth 0x665E3FF6,0x46CC,...
    31 Dec 2002
    Is this something you really want to build yourself? You said $100 isn't a big deal, what about ~$200? There is a wireless USB standard and there are products showing up on the market now (a quick google search).
    If you still want to do this as a DIY thing, I can offer help with the USB part, but I don't know anything about the possible radio development kits out there.
