Networks Wireless ADSL Sharing
Discussion in 'Hardware' started by Guest-2867, 17 Jun 2003.
  1. Guest-2867
    Guest-2867 Guest
    Thinking aboutgetting adsl for my pc, but my parents also want it downstairs on the old pooter. Question is, what wireless things will I need? I want to go for 54G, I have an inkling that all i'll need is 2 network cards, or will i need an access point aswell ?
  2. herbs
    herbs Nobody but us chickens
    7 May 2001
    It's probably best that you get router with wireless access point built built in. Then use a wireless card in the pc downstairs to connect.
    Visit www.adslguide.org for some reviews on the routers but I believe most people on a budget think about the X-modem and the buffalo wireless router but I could be wrong. It might be a good idea to visit the forum as I fairly certain this question has been asked there a few times.
  3. Guest-2867
    Guest-2867 Guest
    Cheers m8, I'm thinking about getting the Belkin 54G stuff, so, does the wireless router with access point plug into my pc via rj-45 or do i still need 2 wireless cards?
  4. sinizterguy
    sinizterguy Dark & Sinizter
    25 Jul 2002
    Since it is a router, one computer can attach directly to it through LAN ... and only the computer away from the router will need a wireless card
  5. Guest-2867
    Guest-2867 Guest
    right, what i've decided on doing is connecting the adsl into my pc, then get a wireless card in both pcs, on the wireless side of thing, will i only need 2 wireless cards, bit like a conventional X-over cable in 10/100 networks ?
  6. sinizterguy
    25 Jul 2002
    Yeah, you can connect two PCs with one wireless card each. You dont need an access point or anything.
  7. Guest-2867
    Guest-2867 Guest
    cheers for the help guys :D
