Networks wireless antena cable
Discussion in 'Hardware' started by Gascan1888, 8 Feb 2008.
  1. Gascan1888
    Gascan1888 What's a Dremel?
    15 Dec 2004
    i want to extend my wifi antena a little and was wondering if there would be any problems using coaxial cable?? i wouldn't think there would be much of a problem since its shielded. i'll have to see what kinda sma connectors i could get. i'm just not sure if there are any reason this wouldn't work well.
  2. Cabe
    Cabe What's a Dremel?
    14 May 2002
    without the right equipment the loss from the connectors will kill your signal. I know its not the bit-tech way but buy premade, they arnt expensive.
    http://cpc.farnell.com/jsp/search/b...arch_003&Ntt=reverse+SMA&Ntx=&_requestid=1562
    or
    http://linitx.com/viewproduct.php?prodid=11751
    Sorry for UK links, but they should let you find what you are looking for.
    if you do want to make it yourself you need Reverse (sometimes called RP/Reverse Polarity) SMA, a socket and a plug (obviously) and some small gauge coaxial cable such as RG174, you can get RG58 connectors, it has less loss but its much bulkier.
  3. Gascan1888
    15 Dec 2004
    hhhmm ok. it was just an idea casue i have alot of coax layin around. but ill look around to see what premade ones i can find.
  4. Oreon_237
    Oreon_237 CHEA BRO!
    11 Dec 2007
    what sort of coaxial do you have. CNT-400 or LMR-400 have low loss and can flex a little (cant go around a tight radius).
  5. johnmalc
    johnmalc That shouldn't happen....
    7 Jul 2007
    As even the best made cables have rated losses of 1.3dBm/metre you don't want long ones...
  6. Gascan1888
    15 Dec 2004
    i remember for sure but im pretty sure its not low loss.
  7. Splynncryth
    Splynncryth 0x665E3FF6,0x46CC,...
    31 Dec 2002
    You will need to impedance match the cable, otherwise the SWR will be really bad. The connectors are just part of this, the right coax is the other.
    Another problem is getting the length of the cable right to get a good SWR.
    Unless you are a radio enthusiast, the premade cables really are the way to go.
