Networks Wireless bridging (attn. Koolvin)
Discussion in 'Hardware' started by Phil, 25 Oct 2001.
  1. Phil
    Phil What's a Dremel?
    19 Jul 2001
    I live in a big student block of flats, which used to be owned by the nearby university but is now privately owned and run.
    I've been desperately trying to get NTL to fit me a cable modem but they're muppets and they jsut cannot and will not lift a finger to do it....even though the whole place here is already cabled (we get all cable channels free...well, inclusive in £65/week rent)
    I have some friend who live about 4 doors down, it's just under 100m distance. Not sure about clear line of site here though...
    They have a cable modem, and say they don't mind me bridging my networks to theirs if I buy all the equipment
    I've read a bit about various bits of kit and they all seem horrensously expensive, is there any way I'm a) going to be able to do this and b) for less than a small fortune (i'm anticipating over £200 already)
  2. Ataraxia
    Ataraxia <b>OOH BABY!!!</b>
    12 Mar 2001
    we're currently testing wireless networking here.. i'll see if I can find out the range/cost etc of the system we've got
  3. moose
    moose What's a Dremel?
    12 Mar 2001
    I hear Koolvin's Netgear kit is 'bog' compliant, if that's any help :D
  4. Ataraxia
    12 Mar 2001
    It's a Cisco Aironet we've got.
    [edit: ...which is £250 just for the host PCI card.... then you need the base station and probably an antenna or 2 as well - it's rated at 30m as standard]
    by 'bog' compliant, does that mean it fits in the sh*tter?
  5. linear
    linear Minimodder
    5 Oct 2001
    We bridged across a courtyard with less-than-perfect line of sight, about 150m. We used Aironet gear too (pre-Cisco) and it was tits (SNMP manageable, spiffy web GUI, etc.). But antennas are the thing. You'll need an antenna configuration that has adequate gain to do the distance and bandwidth you want. I used 6dB patch antennas ($80 or so) but you could build a Yagi with a bit more gain and more directionality for $15 yourself, just Google around for Yagi and pick a design for 2.4 GHz. With the right antennas, even the home gear should get you there.
    Check this out: http://www.pbs.org/cringely/pulpit/pulpit20010628.html
  6. RTT
    RTT #parp
    12 Mar 2001
    yes i heard that too :D
  7. Phil
    19 Jul 2001
    The cost of this all is just insane :(
  8. Forsaken
    Forsaken GameFaction.com
    27 Mar 2001
    aye, Koolvin in the crapper posting news :p
