Networks Wireless card
Discussion in 'Hardware' started by stormbringer500, 11 Jan 2010.
  1. stormbringer500
    stormbringer500 What's a Dremel?
    6 Jan 2010
    Hi, my wireless PCI card recently broke and I'm in need of a new card. I'm using windows vista and windows 7 so I need one compatible with Vista and 7, both in 64-bit. Any suggestions? Looking for a reliable card with WPA2 support. Thanks.
  2. adam_bagpuss
    24 Apr 2009
    does it have to be PCI ?
    if not the best one ive found and used alot is the Abit Airpace 54mbps.
    its a beast has postional antenna and works in vista and 7 64-bit.
    although for windows 7 u have to use the atheros built in drivers not the manufacturer ones.
  3. stormbringer500
    6 Jan 2010
    Thanks, i'll check when I get home cause my graphics card is quite big and takes up a PCI-E slot.
  4. PortalBen
    PortalBen Minimodder
    22 Nov 2009
    I have an Edimax wireless N card. It's very good and has 3 positional antennae so you get good range (or at least I do with my router, also Edimax).
    Much recommended card, unfortunately I can't remember the name of it but I'm prett sure it was bought from Amazon (birthday present).
  5. Fazed
    Fazed Minimodder
    5 Jul 2009
    +1 on the Abit Airpace.
    Been using mine for 6 months and it's rock solid, it's never dropped out on me.
    FYI, it's PCI-E x1 card, but can be used in a 4x, 8x or 16x for that matter, so whatever you have going spare. I have mine in a 4 xslot.
    My experience, Win 7 x64 found and installed the driver automatically, however, with Vista x64 you need to install the bundled software/driver, then manually update the driver through Device Manager by pointing windows in the direction of windows/system32. The only way I could make it work, and a quite a few others had the same problem, but that's no great shakes, IMO.
    All in all, it's fantastic card, with the added bonus of the external antenna, with plenty of cable.
    BT did a review.
    http://www.bit-tech.net/hardware/networking/2007/06/24/abit_airpace_wifi_pci-e_card/1
  6. stormbringer500
    6 Jan 2010
  7. stormbringer500
    6 Jan 2010
    I got Abit Airpace wireless adapter and works really well, with this one im constantly getting a full signal with my past ones the signal has not been as strong. Thanks for recommending.
