Networks Wireless connection keeps dropping
Discussion in 'Hardware' started by SJH, 8 Nov 2007.
  1. SJH
    SJH Minimodder
    24 Dec 2003
    Hi guys,
    My wireless router keeps kicking me off the network.
    Usually it works fine for a few minutes and then I get the "Limited or no connectivity" message. Repairing the connection usually gets the machine's IP reassigned but it gets dropped from the network again after 1 or 2 seconds. After this it normally takes 7 or 8 repair attempts to get an IP assigned and not be kicked off the network.
    The router I'm using is a Linksys WRK54G. Wireless signal strength is usually in the "Very Good" to "Excellent" range.
    What do people suggest doing here?
    Sam
  2. Arthur2Sheds
    Arthur2Sheds Jackson
    19 May 2003
    What's the wireless card protocol? I had a similar issue a while ago with a draft N card and had to tweak security and other settings to get it to play nice with the router.
  3. kevin5k
    kevin5k Lost in Translation
    13 Oct 2007
    R U using the in-built Windows Wireless Manager or 3rd party wireless software to handle your wireless connection?
  4. CaseyBlackburn
    CaseyBlackburn Network Techie
    27 Jul 2004
    Have you tried turning off the router and turning it back on later?
    Is the router getting hot and possibly overheating?
    Have you tried without any Wireless Encryption to see if the problem persists?
    Is the router up to date in firmware?
    Does this problem happen with other wireless devices?
