Networks Wireless connection weirdness
Discussion in 'Tech Support' started by TSDAdam, 17 Feb 2011.
  1. TSDAdam
    TSDAdam Beard!
    28 Jan 2011
    I've got a wireless PCI card with external antenna and a good, strong connection to the router downstairs.
    Every time I play BFBC2 it behaves normally for anything from five minutes to an hour, but then will randomly drop out of the game saying that it lost connection to the server. This is regardless of which server. As soon as it happens if I drop back to the desktop I don't have internet access (no names can be resolved) but the wifi connection still shows as strong for a minute or so, but then I'll get the 'alert' icon on the connection in the systray. Normally hovering over this shows 'No network access' and sometimes 'No internet connection'. It'll stay like this for a minute or two, then suddenly be fine again.
    I would test it with other games, but it's a new build and so far I only have BFBC2 and Civ 5 on it.
    I've tried uninstalling/re-installing the drivers for the card (it's an Edimax), but annoying you can't install the drivers without installing their own connection manager software, I'd normally let windows handle it all.
    I'm running an Asus Mobo with 4GB of Corsair RAM, a Phenom II X4 965 and an EVGA GTX 460. Windows 7 64bit Home Premium.
    The only thing I can think that may or may not be at fault is the fact that the GTX 460 apparently requires 450W, and my PSU is a Corsair 430W. Although I'd expect that to manifest itself with some kind of graphics problem first(?) but I've had none.
  2. adam_bagpuss
    24 Apr 2009
    welcome to wireless doesnt matter how good it is you cant beat a hard wired connection. ive just set up a NAS in my friends house and he was connecting via wi-fi on his laptop which showed good signal strength and i could ping it with <5ms but low and behold sometimes it would take forever to access files from the NAS. ive switched it to hardwired and oh look works pefectly.
  3. TSDAdam
    TSDAdam Beard!
    28 Jan 2011
    It's just so odd, it still shows a full, strong signal while this is happening. It's like it's still connected to the router it just can't talk to it. I can't even get to the router's page on 192.168.... That's not a DNS/resolution problem as far as I can tell, not with direct addressing.
    The old PC that was sat in the same place ran for years with a much cheaper card/antenna without it happening.
  4. Palmski
    Palmski What's a Dremel?
    10 Feb 2011
    Do you have any encryption on your wireless? I found that with my network WPA kept dropping out (I guess as it exchanged a new set of keys) so I fell back to WEP and it has been rock solid since then. Not as secure though but I trust my neighbours ;)
  5. TSDAdam
    TSDAdam Beard!
    28 Jan 2011
    Yeah I am actually, WPA2-PSK
    I'll give that a go tonight and report back :)
    The only other thing I can think of is that the router is running in a mixed N/G mode, and the stupid Edimax software shows itself only as running in G, I guess I could drop it back to straight G on the router, even though the card says it supports N.
  6. adam_bagpuss
    24 Apr 2009
    i wouldnt drop back unless i had to
    its better to run it in N mode only than G mode only since N is much better.
    unless you need the G that is which makes my comment pointless
  7. TSDAdam
    TSDAdam Beard!
    28 Jan 2011
    The Wii is connected wirelessly too which means I can't run in just N :S. I found a guide from Edimax explaining how to install and use Windows Zero Config instead of their own connection manager so I'll give that a go too.
  8. paisa666
    paisa666 I WILL END YOU!!!
    4 Mar 2009
    what router do you have??... if its d-link they are known for this behavior witch you can solve by downloading their latest firmware from their web page
    www.d-link.com
  9. TSDAdam
    TSDAdam Beard!
    28 Jan 2011
    It is a D-link actually, for some reason I had it in my head that it was a Netgear :S Must be the last one I had. I'll check for a more up-to-date firmware when I get home. I do get another odd problem with it where I lost internet connection yet the DSL and internet lights both stay lit. The only way to get it working is a reboot - I have the reboot page bookmarked :S
    Not exactly the same, but very similar to this one (maybe the case has changed in the two years I've had it).
    http://www.dlink.co.uk/cs/Satellite...95808621247&pagename=DLinkEurope-GB/DLWrapper
  10. paisa666
    4 Mar 2009
    hahaha... yes mate the exact router reference wich cause this problems.. go for their latest firmware.. your problem will be solved
  11. TSDAdam
    TSDAdam Beard!
    28 Jan 2011
    Many thanks, rep coming your way if it works ;)
  12. paisa666
    4 Mar 2009
    Hey man how did it go, did you solve the problem??
  13. TSDAdam
    TSDAdam Beard!
    28 Jan 2011
    I don't know yet. Here's what I've done so far:
    1. Updated firmware. The router I'm running is actually an older version, the B. The firmwares on the official UK site are really outdated, I found a more up-to-date one on their Polish site. I called D-Link too who recommended a version lower than the one they ship with now...
    2. Reinstalled drivers. I found a way of installing the drivers without their own wireless network manager, so I'm just using the MS Zero Config tool instead
      Neither of these seemed to fix it, so just today I've tried...
    3. Dropping from mixed 802.11 b, g and n mode, to straight 802.11g, and
    4. Dropping from WPA2 to WPA
    I'm still getting some oddness when streaming through ps3/xbox to the TV (film hangs, if I pause it, wait a minute and hit play it carries on. If I leave it it says it can't play the media and drops out), I think all I can do is keep trying things. It's so annoying. I've got a Netgear router arriving next week anyway, so if all else fails hopefully that'll sort it. Next step in desperation is to move to a different channel I think.
  14. TSDAdam
    TSDAdam Beard!
    28 Jan 2011
    A quick update, and things seem to be more stable. I've not had BFBC2 throw me out (jinxed now) and streaming video to the PS3 is fine, watched two films with no dropout at all. I think it was the switch to 802.11g only that's done it.
  15. paisa666
    4 Mar 2009
    Good to know things are starting to working out for you
