Electronics wireless parallel circuits....?
Discussion in 'Modding' started by One~Zero, 3 Aug 2005.
  1. One~Zero
    One~Zero New Member
    9 Sep 2004
    I was wondering if anyone could point me in the right direction as far as getting a parallel wireless circuit with control data (i.e. D0-D7, init, strobe, /wr, /rd). I'm assuming this would be considered a 12-bit format? I am trying to make a wireless graphical LCD....why you ask? Why not :D
    If any one has come across something along these lines, or know where I could start, it would be much appreciated. Thanks.
  2. chopsuwe
    chopsuwe New Member
    9 Jul 2002
    They don't exist. The closest is to convert to serial, transmit, recieve and convert back to serial.
  3. star882
    star882 New Member
    19 Mar 2003
    Actually, there is. It's called spread spectrum. However, it would be easier to just send the data serially.
  4. Skylined
    Skylined Active Member
    3 May 2003
    They exist, I've seen them by accident some months ago.
  5. iamnafets
    iamnafets New Member
    24 Feb 2005
    Binary voltages on an analog signal? Like starting with .25v for the lowest, moving up to 4v for the highest. A signal like 7.75v would mean 11111? A to D is a chore though, and you mine as well go serial by that point. Nevermind.
  6. g0th
    g0th New Member
    12 Apr 2005
    I'd be doing something like this:
    Parallel (or RS-232 or USB) port ---> microcontroller---> 433MHz data Tx
    433MHz data Rx---->microcontroller---->LCD Module
  7. FourDee
    FourDee New Member
    6 Mar 2004
