Hi Guys, Can anyone recommend a cheap and cheerful PCI wireless network card? It must be windows 7 64x compatible. I have gone through two Belkin wireless USB adapters and am fed up of them constantly dropping connections mid way through gaming/downloading and need something more reliable. CCL is around the corner from me and I can easily pop in there later today to get what I need. Would something like this do the trick for gaming or will I need to spend more? http://www.cclonline.com/product/44...-PCI-Adaptor-with-Detachable-Antenna/NET1468/ Cheers!
personally id have the tried and tested Abit airpace from scan instead of the tp-link and should be cheaper or same price not saying its bad but not sure either way.
I tried one of those long ago, they were fine. I'd always jump on the Airpace++ bandwagon, but the op did specify PCI.
Correct! It wasn't until I had opened up my PC to put the TP-Link card in that I realised I had a PCI-e 1x slot free! Ah well!
