News Wireless power 'superlens' extends range significantly
Discussion in 'Article Discussion' started by Meanmotion, 15 Jan 2014.
  1. Meanmotion
    Meanmotion bleh Moderator
    16 Nov 2003
  2. hyperion
    hyperion Minimodder
    30 Jun 2007
    This is really interesting because if this technology was implemented everywhere then gadgets would simply operate like they were permanently plugged in and batteries would be like auxiliary units that would only come into use when in nature. If it's powerful enough maybe they could lay the technology down on the streets and electric city cars could operate without the current autonomy limitations of fuel cells/batteries, and even lose the weight of those batteries entirely.
    Does it have any effect on animals, like frying your brain or anything?
  3. desertstalker
    desertstalker What's a Dremel?
    7 Feb 2004
    At the power intensity needed to do more than slowly charge a phone, probably.
  4. Corky42
    Corky42 Where's walle?
    30 Oct 2012
    Not sure where people get this idea, wireless power doesn't send electrical current through the air. Maybe they should have called it electromagnetic power as that is what most wireless power uses, an electromagnetic field cause the coil in the receiving device to generate voltage.
    At worst you may find your keys or other metallic things sticking to the charging unit.
  5. crudbreeder
    crudbreeder What's a Dremel?
    29 Mar 2010
    But the electromagnetic field is what fries your brain, just like a microwave oven.
  6. RichCreedy
    RichCreedy Hey What Who
    24 Apr 2009
    electromagnetic field is just a magnetic field produced by a few electrons moving through a wire, it is no different than a magnetic field produced by a magnet other than it moves. a much larger magnetic field is produced by the earths metal core.
    as for the microwave, that works by radiation which vibrates water molecules to heat things. this radiation is produced by a magnetron
  7. Corky42
    30 Oct 2012
    You don't get you brain fried when you go in a MRI and that uses a much more powerful magnetic field, you seem to be confusing magnetic fields with radio waves.
  8. ModSquid
    ModSquid Modder
    16 Apr 2011
    But can you catch it from toilet seats?
    ch424 likes this.
  9. Alecto
    Alecto Minimodder
    20 Apr 2012
    Exclusively.
  10. Bonedoctor
    Bonedoctor Have you turned it off & on again?
    9 Jan 2011
    No, but it does heat things up, especially any metal implants
  11. Corky42
    30 Oct 2012
    Like i said a MRI is much more powerful, around 5,000 to 30,000 gauss.
    If we get to the stage of needing LN2 to cool the electromagnets in an inductive charging loop we will have more to worry about than heating up metal implants.
  12. siliconfanatic
    siliconfanatic Johny-come-Lately
    10 Sep 2012
    Such as batteries exploding like a miniature nuke from being overcharged by unheard of proportions?
Tags: Add Tags
