My mom has an HP Officejet J6400 printer/scanner/copier/faxer that she has been using to print to wirelessly for a year or two now. Starting yesterday the printer will print about three pages and then it drops "offline" and refuses to print. So far the only solution I've found is to delete the printer from windows and then to re-add it. But then it dies again after a few pages. Has anyone had a similar problem or does anyone know what I can do for a more permenant solution? Also, hooking the printer up through USB isn't an option because the computer and printer are in different rooms.
you can try this.. I had to add my hp printer like that to print through the network http://forums.techarena.in/windows-vista-network/900474.htm
