Networks Wireless Router
Discussion in 'Hardware' started by isaac12345, 14 Aug 2008.
  1. isaac12345
    isaac12345 What's a Dremel?
    20 Jul 2008
    Hello,
    I would like to buy a wireless internet reciever for my comp at uni for recieving wireless internet. I am confused with what to buy?should i buy a router, hub or a usb adapter?I was thinking of buying the DLink DI-524.Can it also act as a normal adsl router(for future proofing)?
  2. ComputerKing
    8 Sep 2006
    an USB Adapter or PCI card will work. You don't need a router to receive. Routers send internet.
    any thing From DLink to Linksys to blinkin to Net Gear to 3Com
    just check the sender ( Router ) the University have.
    If it's G go for G type adapter and try to get a good ant. , If it is N go for N type Adapter and you will be fine ;)
    and welcome to BT ;) I hope you enjoy it
    again Routers SEND ONLY! Adapters receive ONLY
  3. Atomic
    Atomic Gerwaff
    6 May 2002
    If you are going to uni and want the internet a PCI Wireless card is what you need for a computer.
    Most uni rooms have a network port to plug into to get access to the nternet so as long as you have a network port on the back of your computer you will be fine then.
