News Wireless USB by Year End
Discussion in 'Article Discussion' started by GreatOldOne, 26 May 2005.
  1. GreatOldOne
    GreatOldOne Wannabe Martian
    29 Jan 2002
  2. jezmck
    jezmck Minimodder
    25 Sep 2003
    Will be great, but as you say - do we really need another wireless option?
  3. DarkReaper
    DarkReaper Alignment: Sarcastic Good
    9 Jan 2004
    So how will this work? Another PCI card, with with an aerial out the back instead of USB slots? Plug a USB-B wireless dongle into all your devices?
  4. Guest-16
    Guest-16 Guest
    Isnt it called bluetooth?
  5. sgtpeppa
    sgtpeppa What's a Dremel?
    16 Nov 2004
    USB without the power?
    Yay, bluetooth?
  6. monkeyville
    monkeyville Evilish Monkey ++;
    3 Aug 2003
    Hopefully it'll drop the price of bluetooth then. :thumb:
  7. ZERO <ibis>
    ZERO <ibis> Minimodder
    22 Feb 2005
    the hole point is that wireless usb 2.0 is as fast as wired usb 2.0 this means that gamers for example can finaly start to buy wireless mouses that do not lag ar go to slow like bluetooth. also thi8s makes devisel like wireless harddrives posible and many other cool stuff that would need hi banwith.
  8. boycee
    boycee What's a Dremel?
    9 Jan 2002
    could this mean finally lagless mice and keyboardS?
  9. <A88>
    <A88> Trust the Computer
    10 Jan 2004
    Could this finally mean cheap wireless webcams for potentially exciting uses?
    <A88>
  10. Cheap Mod Wannabe
    Cheap Mod Wannabe What's a Dremel?
    7 Feb 2005
    If it's working just like USB, only cables are replaced with wireless signals then Wireless USB not like Bluetooth at all. Major bluetooth disadvantage is that it requires various drivers, programs and settings in order to work. Wireless USB a lot simplier and faster thus taking out bluetooth out of Desktop PC's.
  11. Anakha
    Anakha Minimodder
    6 Sep 2002
    I'd love to know how they intend to transmit the power that 9/10 of the USB devices these days use (Wireless USB Christmas lights?).
    Wireless power would be truly fantastic, though most likely very difficult (If not impossible) to make, or at least make safely. Think high-power microwave transmissions - not being able to hold your mouse as the "Power" transmissions would fry your hand...
  12. nick[x1]
    nick[x1] What's a Dremel?
    1 Nov 2004
    Well for the devices that dont use the power, like my digital camera, it would be great but then again its another thing just to be lost
  13. Guest-16
    Guest-16 Guest
    Last time i checked bluetooth was a serial, wireless data transmission and last time i installed something usb it required various drivers and settings in order to work.
    Ok, bluetooth is the equivilient of COM ports but wireless which makes it **** so i do see your point.
  14. LAGMonkey
    LAGMonkey Group 7 error
    4 Aug 2004
    i just hope it dosent run on the 2.5ghz spectrum as thatll add another problem to the already crowded airwaves. I need fast WiFi not a fast com port :wallbash:
  15. Bradish
    Bradish What's a Dremel?
    7 Mar 2004
    I think that is exactly the idea the industry had in mind when they were in concept with the idea :rock:
  16. GMan
    GMan Minimodder
    14 May 2004
    Sounds interesting, but I personally don't want to deal with batteries or worse - more wall warts.
  17. DriftCarl
    DriftCarl Minimodder
    2 Nov 2004
    Excellent, so this means wireless USB TV. I hate having to have my PC next to my TV wall socket, it means I can put my PC anywher ein my room now.
    Also for those who use USB cable modems. they can truely put their PC anywhere now, depending on the range. who needs expensive wireless routers and PCI cards when a wireless USB link will sort it.
    I do like the idea of having a wireless USB web cam at my front door now so i can keep an eye on stuff.
    another cool bonus would be to link my phone to my PC and receive calls through the PC without the phone making that awful "mobile vs speaker" sounds as I could keep the phone some distance from the PC with wireless USB.
    Sure I wont be able to use my keyboard and mouse this way due to lack of power, but a keyboard and mouse are something that needs to be relativly close to your PC anyway. and I am sure because of this, people will invent USB mice and keyboards with built in bateries and wireless USB.
  18. Captain Slug
    Captain Slug Infinite Patience
    25 Nov 2001
    wireless = more annoying and buggy than cords
    Cords don't require batteries or device syncing.
  19. <A88>
    10 Jan 2004
    Even though I've been a bit of a corded person, I'm starting to get into the whole wireless thing, I just wish they'd sort power issues out. Why do we have rechargable mice but not keyboards?! imo if you're going to make something wireless then a charging station or cable is a must.
    <A88>
  20. ArtificialHero
    ArtificialHero We were just punking him sir!
    25 May 2004
    because keyboard batteries last _months_, and it's just another cable to clutter up your desk. I've had my DiNovo set for two years, and changed the batteries three times, for each of the two keyboard bits. The mouse, however, complains if you don't dock it when you're not using it - as far as i can see it doesn't have a sleep mode, so if you leave it on your desk it just drains its battery. Is this the same for the rest of the rest of the MX series, as it seems to me it's a significant flaw - maybe they thought it was worth it as it avoids waiting for your mouse to wake up.
    AH
Tags: Add Tags
