Electronics wiring laptop monitors up, for normal use..
Discussion in 'Modding' started by BitFlip, 24 Nov 2002.
  1. BitFlip
    BitFlip What's a Dremel?
    6 Jul 2002
    im thinking about buying laptop screens, if it is possible to wire them upto a VGA connector and some sort of power suppy?
    are there any guides on this? or has anyone done it.
  2. sinizterguy
    sinizterguy Dark & Sinizter
    25 Jul 2002
    Apparently you need expensive controller cards to connect up laptop displays to normal pcs (they cost in the range of £150+ depending on models I think)
  3. acrimonious
    acrimonious Custom User Title:
    8 Nov 2002
    Is there not some form of conroller in the laptop allready?
  4. sinizterguy
    25 Jul 2002
    In the laptop yes, but it is integrated into the lappy mobo ...
  5. BitFlip
    6 Jul 2002
    surely, you can jsut connect the the wires from the lead which comes from the screen to a vga pin layout, with the rest of the wires used to control the power?
    i've seen somone use a laptop screen for there main pc, but i cant find the link.
  6. bradford010
    bradford010 Bradon Frohman
    7 Dec 2001
    If you have a VGA-in port, then crack it open and see how integrated the controller is with the mainboard.
    You'll also have to power the backlight.
  7. BitFlip
    6 Jul 2002
    well after reading that post on the Integrating laptop LCD into a Lian-Li. From what i understand you have done it a budget cost? with that circuit you made?
  8. bradford010
    7 Dec 2001
    Yeah, a lot of people confuse Charlie Cat's work for a laptop display. It was a touchscreen monitor he got on ebay, I think. A nice piece of work and no mistake. ;)
    If you choose to actually track down a compatible controller, you'll probably start at around £60. Do you have any serial numbers to start with?
  9. BitFlip
    6 Jul 2002
    nope. im thinking about buying random laptops on ebay and just taking the screen out of them.
  10. Lorquis
    Lorquis lorquisSpamCount++;
    8 Sep 2002
    believe me mate... more trouble than it's worth... it's EXTREMLY expensive... and from my knowledge
    in a stardard system it goes:
    Digital (gfx card) -> Analogue (VGA cable) -> Digital (Inside monitor)
    but in a lappy it goes:
    Digital (gfx) -> Digital (Inside monitor)
    so try and find a cheepish normal tft...
  11. BitFlip
    6 Jul 2002
    :waah: i wanted to setup loads for my car :(.
    what about if i was connecting it another laptop? same problem?
  12. bradford010
    7 Dec 2001
    Similar problem. Controllers on lappies are designed with a specific panel in mind. Which means only a (relatively) narrow range will be compatible.
  13. BitFlip
    6 Jul 2002
    ok then, changing the topic alittle, how can i get tft/lcds into my car, cheapy?
  14. bradford010
    7 Dec 2001
    Motherboard with Video out, cannabilise a PS1 TFT screen.
