Electronics Wiring LED momentary vandal switch
Discussion in 'Modding' started by Kronos, 16 Feb 2015.
  1. Kronos
    Kronos Multimodder
    6 Nov 2009
    I have one of these which i wish to use as a reset switch on my Parvum. But I have not got a clue how to wire it up. One of the connections has a + sign and diagonally opposite is one with a - sign.
    At the moment I am only using the Power switch and HDD LED headers on the motherboard is it possible to use Power LED header to supply the necessary to the switch LED?
  2. Margo Baggins
    Margo Baggins I'm good at Soldering Super Moderator
    28 May 2010
    + and - will be for the LED, I think the power LED header on the motherboard will give out 5v, in which case you need a 100ohm resistor to give 3.2v @ 20ma, which is about what a white LED wants. Wire the resistor to the + one and wire that one in turn to the + on the power LED header, then just wire the - to the - on the power LED header.
    the other 2 terminals you have, wire those to the reset switch header, doesn't matter which order, just one to each.
    Would be worth sticking a meter over the cables on the power LED header before you solder everything up as it might be 3.3v, but I would of thought it would be 5v.
  3. Kronos
    Kronos Multimodder
    6 Nov 2009
    Cheers Matt that is a big help.
  4. Margo Baggins
    28 May 2010
    If you got all the bits incl mobo header cables etc. you can ship it to me if you want and I can wire it up for you - always an option.
    Infact as it's screw terminals, only really need the mobo headers and wires, i would make one for you but I don't have any of those cables that push onto the headers.
  5. Kronos
    Kronos Multimodder
    6 Nov 2009
    Sounds good to me. Bung me your address mate.
  6. Margo Baggins
    28 May 2010
    If you could send the switch as well that would be great just so I can test it on my computer to make sure it works
  7. Kronos
    Kronos Multimodder
    6 Nov 2009
    I have a couple of spare front case wires a HDD LED and Power SW which I will send along with the vandal switch.
  8. Margo Baggins
    28 May 2010
    Nice, I'll sort it the night of when I get it and get it shipped back with your keycaps the following day.
