Electronics Wiring LED's in parallel
Discussion in 'Modding' started by Stickeh, 18 May 2004.
  1. Stickeh
    Stickeh Help me , Help you.
    20 Jul 2003
    Alright guys?
    Im plaiing to wire some Blue leds in parallel on the 12v line, now i have some 12v resistors to use, but i am unsure as to where they should / can be placed.Should i place an led at the base of each led, or should i place the resistor along the 12v line before it reaches any leds?
    The diagram below may help:
    So can/should i put the 12v resistor in position R| or R|| ?
  2. SteveyG
    SteveyG Electromodder
    23 Nov 2002
    Position R|| is correct for those resistors.
  3. Stickeh
    20 Jul 2003
    alright, so for my next question, how many leds can i wire up in parrallel on the 12v line?
  4. acrimonious
    acrimonious Custom User Title:
    8 Nov 2002
    Depends on your PSU and LED. The average LED draws, say, 20mA which is 0.02 of an amp. A decent PSU can sustain about 28A on the +12V line so 28/0.02 = about 1400 LEDs
  5. nosmo
    nosmo What's a Dremel?
    5 Oct 2003
    Oh is that all ? :D
  6. Stickeh
    20 Jul 2003
    That is what i thought, lol.
    Thanks guys!
  7. Xipher
    Xipher What's a Dremel?
    25 Apr 2004
    Thing is, you also have to take out all the power your Motherboard and other components take from that, you should also include some over head as well, to make sure you don't over draw from the power supply.
  8. Stickeh
    20 Jul 2003
    well yeh, i thought of that too, but tbh, i dont think ill be hooking up 1400 leds anytime soon. i was thinking of just the 10-20 lol
  9. cpemma
    cpemma Ecky thump
    27 Nov 2001
    I'd put 3s in series and use 4,200. :p
    OstickO, you can save on resistors by using 3 blue leds in series on the 12V line, with a 100R resistor to each string.
