Motors wiring lights to ignition
Discussion in 'General' started by bee2643, 26 Feb 2005.
  1. bee2643
    bee2643 What's a Dremel?
    7 Mar 2002
    1998 dodge dakota
    all cars ive driven/owned previously the lights go on and turn off automatically when you turn on the ignition (or off), and id like to do a similar thing to my truck.
    the stereo will continue to play for about 15 seconds after you remove the key from the ignition, and i wouldn't mind doing that even (as the stereo is closer than the fuse box/more conveniant).
    im just not sure how to go about doing it.
    anyone know what to do? :rock:
    i can take pics of anything if needed.
  2. slater
    slater Mummy Says Im Special
    18 Apr 2003
    Well im no expert but i would have thought it would be easyest to just swap the lights circuit over at the fuse box from a fuse thats live all the time to one thats switched by the ignition?
    ofcourse in practice it may not be that simple :blah:
    slater..
