Electronics Wiring up two fans on one switch
Discussion in 'Modding' started by IornRayn, 27 May 2002.
  1. IornRayn
    IornRayn Guest
    Alright, I am about to begin wiring up the final stuff on my new rig, however, I am going to be wiring two fans to a single switch, what would I do for this, I don't want to screw it up, so I thought I would askbefore I tried my thoughts on it, same for my ccfl which will be around soon.
  2. felix the cat
    felix the cat Spaceman Spiff
    11 Jan 2002
    all you need is a spdt switch and then you can have it on and off, just by conencting the two ground leads up to the outer terminal and the ground lead from a molex to the inner...
    if you want me to, i can draw you a diagram...
  3. IornRayn
    IornRayn Guest
    diagram pls
  4. viridius
    viridius What's a Dremel?
    7 Apr 2002
    Find a switch that you like and is rated for at least 0.5A at 12V. Try to get a SPST switch if at all possible. If you get a SPST switch, wire one terminal on the switch to the 12V line on your molex (yellow). To the other terminal, wire the red fan leads from both fans. Wire the black fan leads from both fans to the ground line (black) on your molex.
