I can't seem to choose between these cases (keep in mind there there is gonne be a mach2gt underneath it): nzxt nemesis elite http://www.nzxt.com/products/nemesis_elite/ http://www.nzxt.com/image/2/78/ Medium size tower with window in it. nzxt zero with sentry 1 http://www.nzxt.com/products/zero/ http://www.nzxt.com/image/2/145/ Large tower with no windows but good cooling. original case http://www.xbitlabs.com/images/coolers/prometeia-mach2gt/p3s.jpg http://www.xbitlabs.com/articles/coolers/display/prometeia-mach2gt_4.html Pretty large case someone told me it had good cooling advice needed!
So you've currently got a Lian-Li PC60 and you're going for one of those other cases? I can't say I've ever used an NZXT case, but you might find the quality of construction is a fair bit lower than on the one you've got. If you really must go for one of those two, go for the second one - it's not as ugly as the first one and being bigger; you can fit more stuff in it.
acteally i first picked the nemesis elite but the zero looked better, olso i called the lian-li case the original because its made fore the mach2gt so they pair.
I'd definitely take the Lian-Li over those pre-mod-monsters! But if you've decided to take one of those NZXTs, then take the second one.
Lian Li Definately. Was it really necessary to open a new thread, about cases, when people already told you that lian li is a better choice?
