Witch is the better ???
Discussion in 'Hardware' started by aCe2k, 23 Oct 2002.
  1. aCe2k
    aCe2k What's a Dremel?
    1 Jan 2002
  2. aCe2k
    1 Jan 2002
    Coz both of them are 4-bolt right?
    Btw, what fan to use?
  3. whypick1
    whypick1 The über-Pick
    17 Oct 2002
    1. Swiftech if you can afford it
    2. Yes, both do bolt to your mobo. I think all Swiftech's and Alpha's do because if they didn't, you'd hear a loud snap and see a rather large empty area where your video card and other PCI cards *used* to be, with your HSF sitting at the bottom of your case, probably making you fall down on the floor crying like a little girl.
    3. Depends on whether or not you want to keep your hearing. If you don't care: Vantec Tornado 80mm. If you sorta care, or want to desensitize your ears to loud whining: Delta 80mmx38mm. If you want to keep your hearing (wuss), something thermal controlled, like Thermaltake's Smart Fan 2.
  4. aCe2k
    1 Jan 2002
    :D :D :D
    No seriosly.. what are you guys using out there, coz my setup shure as h**l isn't working as i think the Tt Vulcano 7+ makes too much noice at 5.5V and cpu running @ :
    idle: 51*C
    100%: 56*C
    [Edit]:
    Is 40,6*C messured on the Ram OK?? Never hear anyone talk about that...
  5. j`w0n
    j`w0n What's a Dremel?
    17 Jul 2002
    I'd go with the Swiftech. I think I'll get one.
    Right now I have a Tt Volc7+, and it's nice, but I wan't a safer one that bolts into the mobo.
    Right run I run 40ºC idle and 45ºC load.
  6. whypick1
    17 Oct 2002
    I personally am using a:
    AMD 1.46ghz XP
    Coolermaster HHC-001 HSF (copper + heatpipes + practically Delta fan)
    Gigabyte 7VRXP mobo (sweet)
    Temps:
    CPU: 39-42°C
    System: 36-38°C
    That's at full load too w/ SETI@Home, gaming raises those temps by maybe a degree or two.
    Before you get all worried about your Volcano 7 not "working", try putting the fan back on 12v. And if your ears complain, stab them with Q-tips.
  7. aCe2k
    1 Jan 2002
    I'd like to *bump* you this thread just to tip the readers of what problems my Vulcano has given me...
    As i dont want to blow of another £30, i'm asking advise this time.. though Tt did state that the vulcano would handle an XP2600+ (with i think is ******** XP2000+ MAX!).. where did the get that to work? On the north pole? inside a fridge?
    I can get the Swiftech MCX462U for a resonably:
    GBP £46,70
    USD $72,34
    NOK 565,-
    + shipping (not much £5/$7.7) here localy in Norway,
    but teh Delta fan will prob. blow the heatsink right threw the mobo and out the back :D and taking my hearing with it.....
    So here is what i have to got with...
    *Sorry bout the webshop using frames..*
    http://www.microplex.no/rubweb/varer.asp?UGID=5830&GID=5800
  8. whypick1
    17 Oct 2002
    The Delta wouldn't make the HSF fly through your motherboard. Remember, the HSF is screwed into the motherboard. If anything, they'll fly away together.
