Wont Boot Up
Discussion in 'Tech Support' started by The_Doctor, 10 Jul 2007.
  1. The_Doctor
    The_Doctor What's a Dremel?
    10 Jul 2007
    Hi all
    I have a problem with installing windows on my newly built PC. To see the current status of where i am please check the link and follow the posts, i appreciate you taking time to help me.
    http://forums.ebuyer.com/showthread.php?t=8962
    :duh:
  2. Bungle
    Bungle Rainbow Warrior
    7 Jul 2007
    Until you can get the CDrom as your primary boot, your stuck as far as I'm aware. Which motherboard do you have?
  3. The_Doctor
    10 Jul 2007
    Gigabyte GA-965P-DS4, Pressing F12 shows me Boot Sequence and CDROM is not at the top, the only thing i can do on there is move down to it and press enter. Even if i dont do that it will still attempt CDROM boot, but just fails each time. :(
  4. Fod
    Fod what is the cheesecake?
    26 Aug 2004
    are you sure your windows CD is bootable?
  5. SteveyG
    SteveyG Electromodder
    23 Nov 2002
    I'm not familiar with that motherboard, but my Intel 965 chipset motherboard cannot boot from IDE devices. SATA devices work natively and IDE drives need the special drivers to be used. So it needs a SATA HDD and SATA CD drive (or IDE with SATA converter).
    Could this be your issue?
  6. Sam0r
    Sam0r It's been a while
    24 Jun 2005
    Pft, Timelords. Great at saving planet earth, rubbish with computers:p
    Anyway, what EXACTLY are your system specs? From that eBuyer thread, I'm confused.
    Are you using an SATA HD and an SATA CD-Rom drive? Or, not?
  7. The_Doctor
    10 Jul 2007
    Hi lol, well earth technology is nothing compared to gallifrey :p, Thanks for your help every one, i obtained a new CD today and it loaded fine.
  8. Sam0r
    24 Jun 2005
    Ha, it always comes down to the simple things :(
    Glad you got it sorted :)
