Won't eject from desktop
Discussion in 'Hardware' started by bard, 8 Aug 2003.
  1. bard
    bard Modding isn't what it used to be
    8 Mar 2003
    I have both the CD-RW and the DVD drive stealthed in my computer, and for the past few months I have had icons on my desktop leading to DVD drive and CD-RW. When I right-clicked these and clicked "eject" in the menu, the drives ejected. But not any more. Now when I click "eject", it just says "Windows is searchin for drive F:". Unless there is a disc in it. Then it works...
    So now I have to eject the drives from My Computer, which I find highly impractical. Why has this happened, and how can it be fixed?
  2. Krikkit
    21 Jan 2003
    Have you tried creating new icons on your desktop? the old ones could be b0rked somehow...
  3. bard
    8 Mar 2003
    Created new ones many times. And the funny thing is that they know that they are assigned to F:, but they won't work when there is no disc in the drive. When there are discs in the drives, I can eject normally, using the icons.
  4. Kevo
    Kevo 426F6C6C6F636B7300
    9 Sep 2001
    In the short cut properties do you have the drive letter in the "start in" box?
  5. ConKbot of Doom
    ConKbot of Doom Minimodder
    2 Jul 2003
    Does it work in the My Computer with no disc?
  6. ZapWizard
    ZapWizard Enter the Mod Matrix
    19 Sep 2002
    This may be a problem because Windows always checks the status of shortcuts on the desktop and on the start menu.
    For example make a shortcut on the desktop to a file on a floppy, remove the floppy then watch as windows tries to access that floppy every minute.
    So windows may not want to eject because of this "feature"
  7. bard
    8 Mar 2003
    It says Target F:\, but nothing in the "start in" box.
    Yep, it works in My computer.
  8. Kevo
    9 Sep 2001
    put F:\ in it then :p
  9. bard
    8 Mar 2003
    It won't allow me. It says that "... F:\ is not valid..."
  10. Froggy
    Froggy What's a Dremel?
    10 Jun 2003
    put a disk in then try that thing
  11. Tribal Dragon
    Tribal Dragon Insomniac modder!
    17 May 2002
    well bard... I've just tried and it does the same thing than you...
    looks like you'll have to go through my computer first like I have to do...
  12. bard
    8 Mar 2003
    But... it worked perfectly for a couple of months before this happened! :grr:
  13. Froggy
    10 Jun 2003
    how come you cant just push the faceplate to open?
  14. bard
    8 Mar 2003
    They're not mounted in a manner that allows that. I have removed the original bezel and stuck bay covers on the tray fronts.
  15. Froggy
    10 Jun 2003
    when my friend stealthed his drives he took a small piece of wood and glued it to the bezel so that he can puch the bezel and the wood hits the button.
