Build Advice Wont POST
Discussion in 'Tech Support' started by Jaybles, 11 May 2012.
  1. Jaybles
    Jaybles What's a Dremel?
    12 Feb 2011
    A friend has built a computer and it is not POSTing.
    The spec is:
    Gigabyte GA-Z68AP-D3
    Core i5 3570k
    HD 6870
    Corsair TX650
    Crucial M4
    Seagate Barracuda 1TB (If I recall correctly)
    He is getting constant short beeps at boot, which according to the manual means a power error.
    Any help on troubleshooting?
    Thanks
  2. JohnSheridan
    JohnSheridan What's a Dremel?
    30 Dec 2010
    Graphics card got power cables plugged in?
  3. Jaybles
    12 Feb 2011
    Yes it did have but I took the graphics card out to isolate the problem and its still beeping.
  4. RichCreedy
    RichCreedy Hey What Who
    24 Apr 2009
    put the 4 way cpu power connection on? sometimes its easily missed
  5. Jaybles
    12 Feb 2011
  6. JohnSheridan
    30 Dec 2010
    Have you tried with just 1 stick of ram in to see if it is that causing the problem?
    The ram should populate the white sockets first.
    Also check that 4-pin cpu power cable also plugged in.
    We are assuming that the motherboards bios supports that IB cpu? Website says has to be F7 bios.
  7. Jaybles
    12 Feb 2011
    He ordered a Sandybridge CPU and Scan said they were out of stock and sent him the IvyBridge instead. I assume that they would only change it to something compatible.
  8. JohnSheridan
    30 Dec 2010
    Try the ram thing first - unless you have a SB cpu to try we won't know re. IB support as can't get into the bios.
  9. Jaybles
    12 Feb 2011
    The single stick of RAM didn't work.
  10. JohnSheridan
    30 Dec 2010
    Did you try it in a different ram slot just incase one of the ram slots is borked?
  11. Jaybles
    12 Feb 2011
    Nope still no luck. :(
  12. JohnSheridan
    30 Dec 2010
    This is a real long shot - but what happens if you remove the CMOS battery from the motherboard, wait a 15 secs, put it back in and try to start?
  13. lancer778544
    lancer778544 Multimodder
    5 Jan 2011
    Do you know anyone else with a socket 1155 CPU? I think it might need a BIOS update to support the new Ivy Bridge CPUs
  14. Jaybles
    12 Feb 2011
    Fraid not :/
  15. Kovoet
    Kovoet What's a Dremel?
    26 Aug 2009
    May seem like a stupid suggestion have you tried going into the bios and reset it to default
    Using tapatalk2 on my HTC
  16. benjjamin
    benjjamin needs MORE POWER!
    13 Sep 2010
    Try and have a look behind the motherbaord, take it out if you have to, maybe a standoff or screw is behind the board and shorting the board and the board is not posting due to a fail-safe feature.
    Take out CMOS battery, unplug PSU from wall socket and then hold down the power button for 10 seconds then put everything back together and see if that works.
  17. Jaybles
    12 Feb 2011
    OK, we have graphics output working now, but it isn't accepting (wireless USB) keyboard input and the speaker seems to be still doing the beep every now and then thing.
  18. MarkW7
    MarkW7 Total Noob
    30 Nov 2008
    What did you do to get it that far? Use a PS2 or wired USB keyboard. So you can now get in to the BIOS?
  19. Jaybles
    12 Feb 2011
    My friend said he moved the GPU to another PCIE slot. We have now tried a PS2 keyboard and still nothing. On power on you just see the Gigabyte splashscreen and the F12 etc commands to go into BIOS but it wont do anything.
