Wont shut down
Discussion in 'Hardware' started by burnoutuk, 4 Jul 2003.
  1. burnoutuk
    burnoutuk What's a Dremel?
    18 Feb 2003
    Im runnin windows xp and when i goto start - turn off computer - turn off nothing happens it doesnt work. It just goes back to my desktop any one know why?
    cheers
  2. whypick1
    whypick1 The über-Pick
    17 Oct 2002
    Do you mean when you hit the shutdown button, it goes back to your desktop like nothing happened or it reboots?
  3. ernie
    ernie What's a Dremel?
    27 Jan 2003
    yea that use to happen to me...
    but from what i figure i think the hard drive falls "asleep"
    so when i need to shutdown now i go open up windows explorer and play a movie file or mp3 then close windows media player then shutdown.
    not technically correct way to solve or remedy a problem :duh: but hey it works for me, hope it works for you :thumb:
  4. Ubermich
    Ubermich He did it!
    21 Jun 2002
    ctrl+alt+del
    task manager
    processes
    End Process...
    End Process...
    End Process...
    End Process...
    End Process...
    End Process...
    ect ect...
    ctrl+alt+del again
    shut down
    If that works, repeat again but with just a few processes. Keep doing that until you limit it to a certain process...
    'least that's my thinking...
  5. Melov
    Melov What's a Dremel?
    30 Apr 2003
    My windows 98 SE used to do that. Sad to see they still haven't fixed it.
  6. Supercool
    Supercool Gone.
    31 May 2003
    My sisters computer does it if it has been left idle for more than 2hrs during the day, but I've setup her machine to make windows do its thing and shut down when you hit the power button, which always works even when clicking `turn off` dosen't
  7. burnoutuk
    18 Feb 2003
    Its ok now... i looked at the processes bit and found "games.exe" deleted it and my computers running faster and shuts down so its all ok :D
  8. DaSuperFly
    DaSuperFly What's a Dremel?
    19 Apr 2002
    games.exe sounds like awfully renamed virus :p
  9. DaSuperFly
    19 Apr 2002
  10. Supercool
    Supercool Gone.
    31 May 2003
    yeah, you said :p ;)
  11. HAZAA_69
    HAZAA_69 What's a Dremel?
    5 Jul 2003
    my comp used to do that. Just log out, and then click shut down from the sign in page. i dont know what causes it, but when i reinstalled xp, it fixed it.
