Electronics Woo look how cute it is! (mini LCD) - lots of pics added
Discussion in 'Modding' started by Cheese, 1 May 2002.
  1. Lazy
    Lazy Meow?
    13 Nov 2001
    okay thanks.
  2. moose
    moose What's a Dremel?
    12 Mar 2001
    ..but I'm not sure, as what I pasted might not be backlit?
  3. Cheese
    Cheese Doc
    6 Oct 2001
    {param}
    Side mounted surface mounted leds yes, though as you can see the top of the lcd is a clear window into the back - if youshone 4 3mm leds down this gap and didn't power the backlight (pins 17 and 18) you'd have a good backlight I think.
    Wiring as,
    3 - earth
    4 - +5V
    5 - earth
    6 - // pin 16
    7 - earth
    8/16 - // pin 1/9
    17 - +5V
    18 - earth
    Cheers,
    r.
  4. relix
    relix Minimodder
    14 Nov 2001
    those are ideal to put in equipment like keyboards and mouses, right? muhaha, modzorz!
  5. Lazy
    Lazy Meow?
    13 Nov 2001
    if anybody has got one all wired up already then i would be happy to buy it of them.
  6. Cheese
    Cheese Doc
    6 Oct 2001
    mail/icq me
    r.
  7. Lazy
    Lazy Meow?
    13 Nov 2001
    email has been sent :D
  8. Cheese
    Cheese Doc
    6 Oct 2001
    Ok some more pics,
    Firstly the width of the 20 way connector compared to 16 way normal ribbon cable,
    {param}
    The soldering is pretty tricky (even 2nd time round) I'd pick up a proper 1mm 20 way connector to reduce the soldering difficulty (and I tried to - think the one I wanted isn't in stock at farnell :().
    Cheers,
    r.
  9. Shepps
    Shepps Slacking off since 1986..
    5 May 2002
    U dont happen to know the farnell code for that conector thingie do u?
  10. kanuslupus
    kanuslupus Minimodder
    10 Mar 2002
    Hehe, anyone recall the NASA incident where they forgot to do the metric conversion?
  11. Yo-DUH_87
    Yo-DUH_87 Who you calling tiny?
    6 Mar 2002
    {param}
  12. Yo-DUH_87
    6 Mar 2002
    That, my friend, was the incident Digitalblueshift and I were refering to.
    Crying shame, just think about how many shiney new P4s they could have bought with that money...
  13. kanuslupus
    10 Mar 2002
    Woops :). I skipped some posts.
  14. Cheese
    Cheese Doc
    6 Oct 2001
    Well this unit is parallel (I normally write // instead of parallel tis easier), though they do serial graphic ones - might play with one soon, need to write some software support for it.
    If you look up a normal parallel wiring guide (see the faq) you should be able to work out how I wired this using the connection list I gave a couple of posts back.
    Available in the states? Must bem dunno where though :(
    r.
  15. Glaswegian
    Glaswegian What's a Dremel?
    11 May 2002
    What, why, where & how?
    Ok here we go!
    The LCD panel loks cool, I'm new to the electronics thing mostly, but how would I use an LCD panel, i.e what use is it, how would I go about adding it to my case mods etc & how much would it cost.
    Sorry for all the Q's I'm trying to clue up here as i've not come across any of this stuff before & have only really built PC's overclocked & the usual stuff. :blah:
  16. Cheese
    Cheese Doc
    6 Oct 2001
    Oops sorry for the slow reply... have a read of the lcd faq in this forum, should answer most of your questions, the links to // wiring guides should help you.
    It costs about £16 to wire up this lcd with all the bits, if you want a bigger one I'd look at mo - they still have the nk204 (normal) for about £45 all inc (to import into this country with DHL), which is a much easier display to set up :) Anyway have a read around...
    Cheers,
    r.
  17. Lazy
    Lazy Meow?
    13 Nov 2001
    Spike said the offer had just ended. You can use the lcd to show motherboard monitor information, cpu usage, disk usage, what winamp is playing, how your stocks are doing, and custom messages.
    I am really impressed by mine. It is very useful for checking chip temps while i am playing games.
