Wood Case project updated 06.27.05 update: new parts
Discussion in 'Project Logs' started by legoman666, 24 Aug 2003.
  1. Sc0rian
    Sc0rian Here comes the farmer
    23 Feb 2003
    lol like it good work;)
  2. sqaulidhummer
    sqaulidhummer What's a Dremel?
    11 Sep 2003
    nice , i like it
  3. legoman666
    legoman666 Beat to fit, paint to match.
    24 Aug 2003
    Thanks for all the praise of the fan grills, i didn't expect that much of a reaction :eeek:
  4. legoman666
    24 Aug 2003
    its been a while since an update.... anyways, its starting to come together...
    Right now the sides are beign held together by masking tape, so bear with me here...
    This is just an image of the front of the case. all the holes on the right are for my 12v/7v switches, LED's and reset/power switch. the big hole in the middle of the bottom is for the louvers (grill type thing). the hole in the mid top is for my LCD screen. The middle section will be hinged for access to the drives.
    This is just the left side without the plexi window and unopened.
    Here is the left side with the door opened
    Just the back, still needs everything to be cut out of it, the hole for the PCI/AGP slots, hole for 120mm fan, cutou for PSU and a hole for a 80mm fan above the psu
    This is the trim that will go on top of the case, a piece of plywood will be sitting in the rectangular slot thingy flush.
    This is two pics of the trim that will go on the bottom, it has a chamfered edge and the case will be sitting inside the rectangular slot thingy. neither of these pics is very good...
  5. FlashPanHunter
    FlashPanHunter What's a Dremel?
    22 Aug 2003
    Nice! It looks great. The black interior looks nice through the window too. So whats going on with the front? Any sort of old style gauges or things like that? I like it!
  6. Snitch
    Snitch Supremodder
    24 Apr 2003
    Looks nice.
    Looks like what i call a "Fattower" :p
    Im actually building a wood case in school, COMPLETELY in wood.
    Just made the the stuff to hold it up...
  7. legoman666
    24 Aug 2003
    there will be4 12v/7v toggle switches for some louder fans of mine, each of them will have an green LED that will light up when its set to 12V and turn off when its at 7V. the power switch is just some switch from radio shack, square shaped, red button, black holder. the reset switch is just a smaller version of the power button but its round... hope that answered your question
    oh, and the power LED will be a superbright blue LED and the HDD will be a white LED.
  8. legoman666
    24 Aug 2003
    small update, been working on the louvers recently, but its slow work because I can only glue on 1 or 2 at a time and then i have to let the glue dry before I put on another one. The bottom louver is 1/4" from the bottom and they are spaced 3/8" apart. looking good so far....
    This picture is photoshopped to show what the final thing should kinda look like..
  9. A13n0rma1
    A13n0rma1 Wannabe
    17 Jul 2003
    :clap:
    Excellent work there.
    Is the wood basically surrounding the case with the side panels off?
  10. legoman666
    24 Aug 2003
    more or less, so yeah....
  11. broots
    broots What's a Dremel?
    24 Sep 2003
    Good work, I'm looking forward to see the final result. :D
    About the final finish of the woodwork, why not check out gunstock (right word?) oil? You can get lotsa different types, and with color added, like red oil. That could give a really nice highlight to the "pattern" of the wood.. :) Yes I own a gun. Hehe
    Anyway, keep up the woo.. I mean good work! :D
  12. FlashPanHunter
    22 Aug 2003
    The vent work is nice. They fit perfectly with the general feel of the case, too. Looks like they give nice air flow as well. Nice work!
  13. legoman666
    24 Aug 2003
    update time!!
    as promised (altho a little late) here is the text
    The final satge of glueing on the louvers, using a light to hold one of the stubborn ones in place.
    The backboard, all cut out and sanded
    I put the case together again using masking tape to see wha tit would look like before I glued it. Looks great....
    The left side all finshed sans the plexi window
    just a closeup of the hinges used on the door.
    the left side yet again but with the plexi sitting in it with its plastic covering still on
    The front of the case held together by masking tape, also fitted the LCD screen to see how that would look.
    Being glued! massive clampage.
  14. Astrum
    Astrum Dare to dream.
    8 Mar 2002
    I have to say this looks ****ing sweet. I'll definetly frequent this thread. Keep up the good work :dremel: :thumb:
  15. Yo-DUH_87
    Yo-DUH_87 Who you calling tiny?
    6 Mar 2002
    I neeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeed :eeek:
    Class work dude, class work :clap: :clap:
    I just love the attention to detail, that is one sweet case ;)
  16. sickskater6911
    sickskater6911 What's a Dremel?
    9 Oct 2003
    thats awsome dude....very original
    keep on keepin on
    happy modding
  17. (Ck)Vegeta
    (Ck)Vegeta What's a Dremel?
    23 Jan 2003
    Good Job its Coming along Really Awesome. Your not leaving the Black case inside the Wooden Case are you or is it just so u can even stuff out? Cause i dont think the Black case inside the wooden one would look that great
  18. legoman666
    24 Aug 2003
    Re: :)
    yes, in fact i am, its all explained earlier in the log...
    (edited so it isn't quite as rude)
  19. (Ck)Vegeta
    23 Jan 2003
    Ok no Need to get Rude I havent been Watching any Bit-Tech Mods Lately next time ill Read it Peace. All i did was look at it and Leave a Post sorry Again
  20. Zero
    Zero What's a Dremel?
    13 Sep 2003
    It's VERY hard to see a nice wooden case around... awesome handywork!
