Wood Case project updated 06.27.05 update: new parts
Discussion in 'Project Logs' started by legoman666, 24 Aug 2003.
  1. legoman666
    legoman666 Beat to fit, paint to match.
    24 Aug 2003
    I installed the new button and worked on some more of the wiring... no picture tho because my mother took the camera into work for for a bit... :( I guess you'll just have to take my word for it that it looks really nice.
  2. DeViLSpArK
    DeViLSpArK What's a Dremel?
    8 Sep 2003
    Good work :clap: but the switches in the front looks not so great :(
    but happy modding ;)
  3. legoman666
    24 Aug 2003
    Got my camera back today, heres the pics i promised...
  4. [WP@]WOLVERINE
    [WP@]WOLVERINE What's a Dremel?
    18 Oct 2003
    Simply amazing!!! :clap: :clap: :clap:
    A work of art! :rock:
  5. leber
    leber What's a Dremel?
    7 Dec 2002
    wow great case, I really like the stain you picked. :rock: :thumb:
  6. A13n0rma1
    A13n0rma1 Wannabe
    17 Jul 2003
    Wow. Master of wood and case, I salute you! :rock:
  7. glennd_05
    glennd_05 What's a Dremel?
    6 Nov 2003
    thats a sweet case "cover" man. I just read the whole thread. My dad is a finish carpenter so i can really appreciate the true beauty of wood, its just beautiful. I like the color the Linseed oil gave it :thumb:
    -glenn
  8. Tech-Daddy
    Tech-Daddy What's a Dremel?
    8 Oct 2003
    I read from begining to now... done a great job on the wood, bro!
    Excellent patience!
    IMHO, I feel that the SPST switches almost look like "splinters" jutting out of the front of the case. They break the continuity of what is otherwise, a splendid example of creativity and vision!
    Now, I have never made a wood case, and I have never made a fan bus or a bay bus, so I cant be as forthcoming on the whole "advice/part numbers" suggestion, but I can browse like crazy in Mouser, or I have a serious electronics warehouse here in Dallas that I can browse thru their stocks and if I find something that would work, I'll pic it and post it up.
    However first and foremost... you have done an excellent job on this case. And if the switches are a part of your vision, tell me to STFU and just sit back and enjoy the ride! ;)
    :thumb: :thumb: :thumb:
  9. legoman666
    24 Aug 2003
    Last update (sorta)!!!
    I completed the case and everything is installed in it!
    Only two problems, my reset button seems to be fried, which is no big problem but does need to be fixed sometime...
    and the other problem is with the fan switches. They are supposed to switch the ground on the fans between 0V and 5V, thus changing the fan's voltage from 12V to 7V. But when i have all the fans at 12V and switch one to 7V, the psu makes an odd noise, but the fan does go to 7V. But then when i switch 2 fans to 7V, it works for about 3 seconds and then the psu shuts off. (I tested all of this before I put the system in) Now this really confuses me and Ill make a diagram of the wiring and post it later.
    Pictures:
    um... yeah, my mother has the camera at work again, I'll have it back at 4:15PM today (its 6:41AM now) so until then.....
  10. tm36usa
    tm36usa What's a Dremel?
    21 Jan 2004
    it sounds like there might be a short with ur fan switches if the psu auto offs after about 3 seconds. Mabey you should check ur wiring. I will take a look at the diagram when u get it posted and see where you might have gone wrong. Nice Job! :thumb:
  11. Gnemelf
    Gnemelf Minimodder
    9 Aug 2003
    thats super nice I love seeing woodwork intigrated into pc's.. :) Cause that was my original job :p working with wood... fun stuffs.
    Very nice work too :rock:
  12. legoman666
    24 Aug 2003
    Here are the pics and wiring diagram as promised. If anyone wants a shot from a particular side or angle, let me know and ill see what I can do.
    Theres the wiring diagram, if you need anything explained, just ask.
    Comments welcome! :thumb:
  13. maeterlinck
    maeterlinck What's a Dremel?
    14 Jul 2003
    Hey! Well done - it looks dead good! I'd be tempted to agree with other people in that the toggle switches on the front don't match the general 'look' of the case - but this can be a mod for later! :D
    One thing though - tidy your cable inside!
    re: Circuit diagram, if that's what you've done then all should work. However, I'd guess that something is shorting across or a switch is faulty. Continuity check everything (with the power off).
    HTH
  14. legoman666
    24 Aug 2003
    boink
  15. Tech-Daddy
    8 Oct 2003
    Nice pics!
    Super nice case!
    Sleeve those power cables and get that yellow, red and black attack out of there!
    :thumb: :thumb:
  16. my58vw
    my58vw Plexi Expert
    22 Sep 2003
    Needs some lighting... looks great. I wish I could do wood like.
    good job :rock:
  17. legoman666
    24 Aug 2003
    actually, ive installed a blue CC since i took the pics.
  18. Incorpirate
    Incorpirate What's a Dremel?
    2 Jan 2004
    coolio we want new pics then ;)
  19. legoman666
    24 Aug 2003
    coming right up...
  20. legoman666
    24 Aug 2003
    kinda blurry...
    i need another for the bottom of the case..., i have a UV CC and a white CC, but they dont match the theme of the other lights...
    edit: it appears i exceeded my bandwidth.... i didnt even know i had a bandwidth limitation.... so the pics should go back up soon...
