Case Mod - In Progress WOOD workstation project
Discussion in 'Project Logs' started by pccustom, 3 Oct 2024.
  1. pccustom
    pccustom Multimodder
    12 Jul 2017
    new project stay tuned...
    Cheapskate, Yaka and neSSa like this.
  2. censored_Prometheus_
    censored_Prometheus_ Minimodder
    26 Mar 2019
  3. pccustom
    12 Jul 2017
    first sponsor arrived,stay tuned....
  4. Cheapskate
    13 May 2007
    :worried: "400 pcs"
    400 graphics cards?
    pccustom likes this.
  5. pccustom
    12 Jul 2017
    hello guys here are some more components the project is based on the bequiet silent base 802 a case that I love, thanks to qìbe quiet for sending me these components...
    the brand new aio light loop 360
    as for the motherboard I bought a huananzhi X99 F8 these motherboards are sold with a processor already mounted, in my case it arrived with an intel xeon E8 2620 V3 with 6 cores and 12 threads at a speed of 2.40 ghz however needing a high number of cores I bought another one to replace an E5 2697 V3 12 cores 24 threads at 2.60 ghz the cost of these cpu are really negligible, I remind you that I am assembling and modding a workstation not a gaming pc, so don't turn up your nose.. :) the motherboard has 8 channels in dual channel my intention is to install 8 banks of 8 gb for a total of 64 gb, the F8 supports both ECC and NON ECC this is a great advantage.
    2 top fans to further cool components.
    8 input sata.
  6. censored_Prometheus_
    26 Mar 2019
    OMG! HUANANZHI?! NO, NOT HUANANZHI! :wallbash:
  7. Cheapskate
    13 May 2007
    It'll be OK, Just remember to turn off the spy satellite uplink in the bios.
    Arboreal likes this.
  8. pccustom
    12 Jul 2017
    yesssssss...
  9. pccustom
    12 Jul 2017
    BazzUK likes this.
  10. pccustom
    12 Jul 2017
    please explain better, what you mean?
  11. pccustom
    12 Jul 2017
    here are the rams arrived from ecostryke a few words for this new Italian brand
    Ecostryke was born from a passion for technology and an awareness of the importance of environmental sustainability. Founded in 2024, our company was created with the aim of revolutionizing the IT products market, offering eco-friendly solutions that combine high quality and respect for the planet. We have been committed from the beginning to reducing the environmental impact of our products, using recycled and biodegradable materials and adopting sustainable production processes.i.
    https://ecostryke.com/
    UDIMM DDR4 3200 Mhz 64GB KIT 8X8
    Cheapskate likes this.
  12. Cheapskate
    13 May 2007
    When China bought Lenovo they became infamous for spyware. It was just a joke... I hope. :worried:
  13. censored_Prometheus_
    26 Mar 2019
    Well, Lenovo is Chinese by birth. There's no question about it. And technologies like Meltdown and Spectre for unauthorized access are proprietary to Intel. So no need to worry about that, all the backdoors are guarding democratic ideals.
  14. censored_Prometheus_
    26 Mar 2019
    And about huanandzhi, the company is notorious for using used components to manufacture its products. The motherboards are very finicky when dealing with graphics cards, RAM and ssd. Yes, they are cheap enough, but this purchase is like a lottery where you may or may not get lucky. However, there is no way to win.
  15. pccustom
    12 Jul 2017
    finally arrived!!
    For this project I chose a precious wood of unique beauty, mahogany.
  16. pccustom
    12 Jul 2017
    hello guys back to work.. the goal is to customize this case without modifying the structure so that you can always return to the original state if you want I will use its supports holes etc..
    First thing I'll remove the original fans that came with the case, not that they're not good, on the contrary, but I'll use the new light x wings
    LIGHT WINGS silent Fans for your PC from be quiet!
    140mm PWM high-speed | 140mm PWM | 120mm PWM high-speed | 120mm PWM | 140mm PWM high-speed Triple Pack | 140mm PWM high-speed White Triple Pack | 140mm PWM Triple Pack | 140mm PWM White Triple Pack | 120mm PWM high-speed Triple Pack | 120mm PWM high-speed White Triple Pack | 120mm PWM Triple...
    [​IMG] www.bequiet.com
    I bring the case bare..
    when I ordered the wooden boards from the carpenter I deliberately increased the dimensions by a few centimeters in order to better control the actual measurements given by the case. To do this I use a Japanese-type marker, it has very dense teeth and offers a very precise cut.
    mahogany is a wood that is among the dense and valuable ones, very hard to work manually, but gives a lot of satisfaction. first goal to rebuild the front panel to replace the original on
    the have some supports in my case, I'll make room for them.
    create a 90° angle and then using spa and 80 grit sandpaper, then finishing with 180 and 240 grit, I reconstruct the upper curve.
    These panels will need to be drilled to have optimal airflow.
    now I have to create the supports to insert it into the case, I use the thick holes for the original pins I create them in aluminum easy to model
    a hard job to do manually but in the end..
    top panel, the case has a 90° depression after having cut the board to size I chamfer the corners, the board is 1 cm thick I mark the half and create the lateral curvature
    neSSa, Cheapskate, Yaka and 1 other person like this.
  17. Nexxo
    Nexxo Rotate Your Owl For Science
    23 Oct 2001
    Japanese saws are a game changer. Highly recommend.
  18. Cheapskate
    13 May 2007
    Awesome! :D
    No specialty saws here. Can't afford them. I've always used... fine tooth hack saw blades. I'm also a fan of a 50 grit belt sander belt glued to a board for rough shaping. It's like having a REALLY FAT file and that's great for making even edges.
    Watch out for getting the dust indoors. I know a woodworker that discovered he was allergic to one specific wood.
  19. abbas-it
    abbas-it We came, we saw, we mod, you awe!
    1 Jun 2011
    wow, nicely worked wood
  20. pccustom
    12 Jul 2017
    hello guys here I am again with the creation of the internal panel I base myself on the rounded shape of the frame.. let's go..
    on straight parts I use the Japanese saw but for the hollow parts I have no choice I go with an electric fretsaw..
    I want the edges to be smoothed, I'll take the rasp again...co..
    I get myself some 5mm diameter rods that will fit into the holes already present in the case.
    ower part
    sorry guys but I couldn't resist I'm taking a break...
    Dot_Kappa, Cheapskate, neSSa and 2 others like this.
