Case Mod - In Progress WOOD workstation project
Discussion in 'Project Logs' started by pccustom, 3 Oct 2024.
  1. Cheapskate
    13 May 2007
    Client: "Looks nice, but it smells like sausage." :hehe:
    Dot_Kappa likes this.
  2. Dot_Kappa
    Dot_Kappa 100% Puppet
    23 Mar 2006
    Accomplished plexi master and wood too :thumb:
  3. pccustom
    pccustom Multimodder
    12 Jul 2017
    Hi guys, update on tests with the lower shelf completed.. some spacers will be added to the lower part to facilitate the air flow.
    In the meantime, the new be quiet ìLIGHT WINGS LX fans have arrived which will replace the original ones in the case
    and also the heat sinks for the SSDs... but we'll see them in detail later
    finishing the internal panel using the holes in the case..
    This panel is used to cover the holes for the 3.5" hard drive bays.
    processing of the lower left side panel I use the same geometry as the original bequiet panel
    I'm getting ready to work on the right side.
    these 3 panels will have to fit together perfectly..
    as usual I complicated my life, I'm fine with that... :)
    I help myself with precision chisels.
    these panels will need to be further worked on with the addition of blind ventilation holes, perhaps with parts in aluminium which I haven't decided yet...
  4. Darkened
    Darkened Minimodder
    28 Feb 2004
    Very nice project, it'll be gorgeous with the wood accents.
    Might I suggest a shinto rasp from Amazon (not expensive and beats the rasp easily). And maybe thread inserts made for wood if they're not too bulky. Those inserts made for plastic/3D-printed parts might work well with glue if clearaces are at a premium :thumb:
  5. pccustom
    12 Jul 2017
    Hi guys, let's continue.
    his is the project for the processing of the front and top panel once the dimensions have been established, I print on adhesive paper and apply it to the piece, in this way I have the mathematical certainty that everything will come out exactly as planned.
    I start with 3mm tips and then gradually increase the size.
    these holes, besides being decorative, have an optimal airflow. I remember that this Be Quiet case, which I love, has dust filters everywhere. I was pleasantly surprised.
    better pics coming soon..
  6. Darkened
    Darkened Minimodder
    28 Feb 2004
    Nice work, looks pretty much on the dot symmetric.
    I also use those step drillbits on the regular, because "normal" drillbits tend to create somewhat triangular hole if you're not careful with how you use them.
    pccustom likes this.
  7. pccustom
    12 Jul 2017
    Hi guys, more photos of the case view with the front and rear panel finished, the panels, even if well sanded, still need to be finished with linseed oil
    I had completed the psu cover panel but it still needs other attention, it must be raised a little to favor the airflow with the lower psu components and hard drives. I had inserted some pins in conjunction with holes already present in the case this to position the panel that otherwise would have danced inside the cabinet, I also add some magnets, even if small they are very powerful they screw on the piece, in this way the panel is raised as much as needed for the airflow.
    this way the magnets keep it anchored to the case and it doesn't move. Test on a steel ruler.
    Now it's time to take the right bulkhead that I had previously cut. Once the graphics have been studied always with the procedure used for the front panel, that is, design on PC, print on adhesive paper and then apply it to the piece.
    I wanted to use a three-dimensional effect, I drilled holes of different diameters to create this illusion.
    Central part still to be defined.
    Here too I apply magnets, unlike the internal panel I apply them at the level of the panel, I make holes, I fix them with vinavil glue, once dry it is hard as cement. In this way the boards are applied to the bulkhead without using holes.
  8. pccustom
    12 Jul 2017
    hello guys here I am again with further developments, in this step I will share with you the processing of the external panel that will cover the right bulkhead. These are the various sketches and ideas..
    I have to take into account my manual skills, not having the possibility of using CNC or laser cutting even on behalf of third parties given the high costs, I evaluate some ideas, this will be a 0.8 mm aluminum plate that will be positioned on the central part of the wooden panel, I chose aluminum for 2 reasons, 1 easy and manual processing and lightness. chosen the graphics.
    simulates a sort of elaborate grid with a central logo I design the panel with Adobe Illustrator with exact measurements and then print it on adhesive paper and apply it to the piece
    after applying 6mm holes, do some electric fretwork..
    a long and boring job but which I hope will give satisfactory results in the end
    obviously it's all a bit imprecise and will need to be fixed with precision
    but slowly... I don't want a shiny effect but a bit rough, I use 400 sandpaper and water..
    but in the end..
    This little job took me about 2 days of work
    neSSa, kenco_uk, Dot_Kappa and 2 others like this.
  9. Cheapskate
    13 May 2007
    I really don't know how you keep things so straight.
    neSSa, pccustom, Yaka and 1 other person like this.
  10. Darkened
    Darkened Minimodder
    28 Feb 2004
    I feel your pain with the filing since I'm doing the same here. A sandwich of aluminum and acrylic no less and it's not fun (and I still have polishing the aluminum and the edges of the acrylic to look forward to) :hehe:
    Your parts turned out great though and I'm glad to see I'm not the only one struggling without a CNC router or something along those lines. Keep it coming :thumb:
  11. kenco_uk
    28 Nov 2003
    If you said it was cnc milled, I'd believe you. Looking spot on!
  12. pccustom
    12 Jul 2017
    thank you guys-
  13. pccustom
    12 Jul 2017
    hello guys I'm taking the internal panel again.. this plate has the same workmanship as the external aluminum panel but smaller design on file, printing on adhesive paper and working on the piece
    completed
    it's time to finish the wood, I use cooked linseed oil which, in addition to protecting, highlights all the grain of the wood, darkening it a little.
  14. kim
    kim hardware addict
    10 Jan 2016
    Outstanding craftsmanship as usual :clap: I'm trying to work with hand tools on aluminum for a long time with many disappointing results, I admire your work and skills :dremel::rock:
  15. Yaka
    Yaka Multimodder
    26 Jun 2005
    wowsers, if anyone looked at that they would swear its done by cnc
  16. Cheapskate
    13 May 2007
    Awesome coverplates, like always. -Just this time in wood. :D
    The original aluminum center logo was tricky enough to cut and file. You went back and made it even more delicate. :lol:
  17. pccustom
    12 Jul 2017
    Hi guys, I'm making the support bracket for the inno3d 4070 super. I'll take a piece of aluminum recovered from unio scrap, thickness 1 mm.
    I recover an aluminum angle bracket and apply the 2 threaded rivets to i
    I also recover a piece of leftover mahogany wood and divide it in 2 to halve the thickness.
    these are the finished pieces without first applying 2 layers of matt black
    result
    Cheapskate, Yaka and Dot_Kappa like this.
  18. Yaka
    Yaka Multimodder
    26 Jun 2005
    shame bit tecjh mod of the month is now more, this one would a been a prime contender
  19. Cheapskate
    13 May 2007
    That part is giving me flashbacks to when I designed MNPCTech's support brackets. :lol:
    ...It brought in 80% of our new content. :(
  20. pccustom
    12 Jul 2017
    Hi guys, the mod is practically finished, I'll show you the final photos later, in the meantime I made the headphone holder with the leftover wood that will accommodate the new Sharkoon SKILLER SGH50 headphones
    SKILLER SGH50 - Black - sharkoon.com
    Along with these there will be the new SGK50S4 keyboards and the now well-known SGK30
    SKILLER SGK50 S4 - sharkoon.com
    "> [​IMG]
    mouse SKILLER SGM50W
    SKILLER SGM50W - Black - sharkoon.com
    All this to complete my workstation.. let's go basic preparation
    the lower base is screwed and with the addition of vinyl glue to the central pillar.
    Preparation of the headphone stand, I took the correct curvature from the headphones, I glued 3 pieces of wood with vinyl glue and held them together with clamps for 4 hours, the result is a single block of wood that once worked you can't even see the joints
    Gluing and fixing to the second base which will in turn be fixed to the central base.
    I had this piece of aluminum left over, it was part of a Sharkoon case that I modded thicker than 1mm.
    Paint is hard to remove, paint stripper makes it quicker...
    Sandpaper 180 then 240 then 400 and finally 800 with water.
    Fixing holes at the bottom base.
    I added the tip to the base with another piece of leftover wood. To make the lines straight and at the right distance from each other I use a guide.
    Fixed everything this is the central bracket.
    I fix the base in aluminum.
    I get another piece of aluminum to cover the fixing screws on the back and give more prominence to the structure, this is the result I hope you like it...
    Cheapskate, Ragster and Yaka like this.
