Case Mod - In Progress WOOD workstation project
Discussion in 'Project Logs' started by pccustom, 3 Oct 2024.
  1. pccustom
    pccustom Multimodder
    12 Jul 2017
    update: the case mounts 140 mm fans which, although excellent, I replace with the new LIGHT WINGS XL... the same ones but 120 mm are mounted on the liquid heatsink.
    For those interested in purchasing I leave you the link
    https://amzn.to/4hEmdz7
  2. pccustom
    12 Jul 2017
    80 plus platinum bequiet! 1200W modular power supply For those interested in purchasing, I leave you the link
    https://amzn.to/4gLAbO
  3. pccustom
    12 Jul 2017
    64Gb ram hardware assembly
    2 ssd m2 branded s3plus one of 240 and the other of 480 GB
    on which I will mount the be quiet MC1 heat sinks
    https://amzn.to/3X3BkKg
  4. pccustom
    12 Jul 2017
    Hi guys here some final shots
  5. Cheapskate
    13 May 2007
    That looks fantastic. :D Walnut + black always looks good, but you really did some great work again. Wood doesn't let you make mistakes, so we can see you did a perfect job.
    The empty waterblock mounts on the memory scream for a unitary heatsink or maybe an aluminum coverplate that hides the main wires.
    It's rare for me to say this, but I like the design of the cpu waterblock. Light fade through louvers is one of my favorite things to play with in design.
    Dot_Kappa and pccustom like this.
  6. pccustom
    12 Jul 2017
    thanks! it was the first time I used wood and I think I will do it in the future, the result is fantastic, it gives off heat and the light reflects well, and then if you are cold you can always burn the pc pc to warm up...:) I had these alphacool heat sinks that are designed for liquid cooling to be mounted on, they were sent to me years ago for a project of mine, then I received ram with led and I have not used them until now, yes you are right it would be nice to mount some cooling fans maybe self-built, but I will not do it now... the engineers of bequiet with the cpu waterblock did a great job I like it a lot..
    Dot_Kappa and Cheapskate like this.
  7. Dot_Kappa
    Dot_Kappa 100% Puppet
    23 Mar 2006
    PLexi : OK
    Wood: OK
    What's next ? :grin:
