Scratch Build – In Progress Woody by zwiks
Discussion in 'Project Logs' started by zwiks, 5 Jan 2008.
  1. zwiks
    zwiks My avatar: :D
    2 Jan 2008
    hahaha n1 :p
    but i need to sand it first.
  2. clocker
    clocker Shovel Ready
    21 Dec 2003
    Ah.
    I think block sanding will work.
    Start with the case body and use the longest block of wood you can comfortably maneuver with sandpaper wrapped around it.
    Use a straightedge to get those two edges (top and front) as straight as possible.
    Then fit the sidepanel to those two edges.
  3. zwiks
    zwiks My avatar: :D
    2 Jan 2008
    thank you clocker for youre comment.. but i dont know what a straightedge is .. sorry. i need a little more explanation..
  4. Stuey
    Stuey You will be defenestrated!
    20 Jan 2005
    A ruler is sometimes makes a good straightedge. Then there's also "framing squares" and the such. Basically, any slightly thick straight metallic bar can be used as a straightedge.
    http://images.google.com/images?q=steel+straight+edge
  5. culley
    culley What's a Dremel?
    12 Jul 2006
    Surely as it's got a white primer on the gap between the panels is visable, once you have painted it black it won't be as visable?
    Sikker nemlig det er fik en hvid begynderbog oven på den hul imellem den bedømmelseskomite er påtegning , når først du har malet sig neger sig vil ikke være nemlig påtegning?
  6. zwiks
    zwiks My avatar: :D
    2 Jan 2008
    haha .. i do get youre point.. haha "Sikker nemlig det er fik en hvid begynderbog.." dosen't mean anything its just nonsense in danish haha ..
    but n1 mate.. you do have a point there but i think i use Clocker's good idea..
    and thanks to Stuey to teach me what straightedge is .. heh :D
  7. culley
    12 Jul 2006
    Thought i help you understand abit better, lol though these online translator are good at converting words i doubt they can convert them with accuracy when full sentences are being used, unless you write like a phd english professor.
  8. zwiks
    zwiks My avatar: :D
    2 Jan 2008
    heheh .. yeah thats right .. but thanks for the help.. here is a little bit of it translated direct to english: "Sure precisely it are get a white beginner-book on top that hole between that judgement-committee.." haha its nonsense.. hehe :p
  9. zwiks
    zwiks My avatar: :D
    2 Jan 2008
    Time for some real paint.
    Yeah. Update ..
    Time for some paint..
    Soooo... here it is:
    ..comment would be nice :D
  10. Exeq
    Exeq www.Mod-Planet.com
    11 Dec 2007
    Wow... excellent. What you use to paint? Aero graph or spray?
    Maybe you add some photo of those corners? How it look? :D
  11. clocker
    21 Dec 2003
    Quite a difference.
    Still seeing some white in the panel gap though, did you paint it assembled?
  12. zwiks
    zwiks My avatar: :D
    2 Jan 2008
    thank you..
    im using something like this:
    .. i have only paintet 1 out of 3 layers.. some places you can see a little bit through.. but im posting more detailed pictures after next layer..
  13. modgodtanvir
    modgodtanvir Prepare - for Mortal Bumbat!
    28 May 2007
    aww awesome dude! Coming along nicely and I'm liking the colour. I must say, I have never seen anyone on here use that method to paint a case before, but it appears to be effective. Keep up the good work.
    :rock:
  14. mvagusta
    mvagusta Did a skid that went for two weeks.
    24 Dec 2006
    That is an awesome color & all the curves of the case look excellent :rock: the window, all the rounded edges of the case, everything looks hot! You are gonna paint the dvd the same color right?
    Are you gonna use orange leds to light it up? I hope so, even make the pc power, hdd & dvd activity leds orange :D
  15. zwiks
    zwiks My avatar: :D
    2 Jan 2008
    Thank you guys..
    Yes i do paint the dvd the same color.. and i have nice ac-ryan fans in the plexi-window ..
    The method i'm using was the method that seems most nice to me.. so thats why..
    and yes i am painting it assembled (in my sisters play-house ..hehehe :D:D) :p
  16. zwiks
    zwiks My avatar: :D
    2 Jan 2008
    by the way. i'm posting some new images soon.. cuz i've just painted the second layer :D
  17. zwiks
    zwiks My avatar: :D
    2 Jan 2008
    Yeah new update !! :D [Second layer of paint] and it look just perfect :D
    So here it is: :D
    ^^i like it .. and allso the way the newspaper reflects in the paint :D uhh just sweeet :D^^
    but it still need one layer.. and it can only get better :D jubii i'm happy :D
    ..and remember it needs a dvd-rom (paintet) and a plexiglass window to finish the look..
  18. zwiks
    zwiks My avatar: :D
    2 Jan 2008
    sry. dbl-post
  19. zwiks
    zwiks My avatar: :D
    2 Jan 2008
    heh.. do anyone have a little thing to say? hehe :p
  20. clocker
    21 Dec 2003
    Well, at some point you're going to have to remove the sidepanel and paint the gap...white is still visible in a few places.
    Other than that it's hard to say.
    Need some pics from different angles and with the hardware installed.
